Post by jakesrocks on Jan 18, 2011 22:27:40 GMT -5
Krystee, to the right of the drill press / metal lathe, I see a bench grinder. Check the RPM's on the motor data plate. If it doesn't turn more than 1725 RPM's, that would make a much better buffer. The motor is a sealed unit, so you wouldn't have to worry about getting water or grit in the bearings or motor. And it would take up a lot less shop space. Don
Post by tntmom on Jan 18, 2011 22:32:48 GMT -5
Great info Nate, love DIY, bookmarking it, THANKS! ~K
Post by tntmom on Jan 18, 2011 22:37:41 GMT -5
Don, will check it out, photo and post what I discover! The shop came with the house but is unheated and unused. Wish I would have taken Tech Ed, I would feel much more knowledgable!
Post by tntmom on Jan 18, 2011 22:59:57 GMT -5
Krystee, to the right of the drill press / metal lathe, I see a bench grinder. Check the RPM's on the motor data plate. If it doesn't turn more than 1725 RPM's, that would make a much better buffer. The motor is a sealed unit, so you wouldn't have to worry about getting water or grit in the bearings or motor. And it would take up a lot less shop space. Don Don, Bummer, it appears that the bench grinder is 3450 rpm's Darn it.
