Post by tntmom on Jan 17, 2011 23:22:08 GMT -5
I've been working so hard the last few days on everyone else's year end books, that I just had to get away and seal myself off in the garage tonight. Been working on a dremel cab for the last couple of hours and I'm getting ready to polish. I like this one and thought I would wrap it later tonight or tomorrow... problem is... I can't figure out which end should be the top? What do you guys think? And also... what color wire do you think would make it pop? I have bronze, silver plated, and gold plated. ? ? Thanks for your input! ~Krystee
Post by 150FromFundy on Jan 17, 2011 23:50:09 GMT -5
Definately Photo 2. It hides the small fracture at the tip visible in Photo 1. Gold wire should work nicely with the natural gold tones of your cab.
Darryl.
Post by tkrueger3 on Jan 18, 2011 0:09:03 GMT -5
Oh, yeah! It's gorgeous, and I agree - photo # 2, and definitely gold wire!
Tom
Post by Rockoonz on Jan 18, 2011 0:52:58 GMT -5
I agree that gold wire should be used but IMO you should go with photo #1 and just put a little artistic wire bending at the top to conceal the tiny fracture.
Lee
Post by bobby1 on Jan 18, 2011 1:17:02 GMT -5
To me the darker (visually "heavier") end should go down unless you are trying to give the sense of disruption or unbalance in your piece by going against the usual. I vote for photo 1 and by using the design of the wire wrapping to conceal the minor chip in the crystalline portion of the cab. You are going to have to conceal it regardless of which end is up. Just my perjudices showing. Bob
Post by tntmom on Jan 18, 2011 1:54:50 GMT -5
Wow, see my dillema?
I am checking in, partially done with polishing, re-doing a bit to get it right. Burrs and diamond paste are a bugger. they never produce what you want in the time frame you want....
So, I'm still at a loss as I was to begin with. I am 2 for 2 right now. However, it is confirmed that I will be doing gold wire.
I like what Bob said about putting the "heavy" side down, that is the way I think. But my husband and oldest son disagreed. Looking at the pictures, #2 looks really nice. Gosh, I just don't know. Will wait on a few more responses before making up my mind!
meta99
Ohio Flint Ridge flint
Member since October 2010
Post by meta99 on Jan 18, 2011 6:52:13 GMT -5
I like #1...I think for me the "heavier side down" issue makes the top look like sky and the bottom like earth... more natural FWIW
Sue
Post by Donnie's Rocky Treasures on Jan 18, 2011 7:39:59 GMT -5
I am going for #1 as well. You can conceal the little fracture at the top with your wire & it will also make for a more secure situation for that little fracture. It will be at the top, concealed & more secure should it be dropped or bumped because you can use your wire to give it some protection.
Post by Toad on Jan 18, 2011 7:44:50 GMT -5
I like dark side up, so photo 2
lonetreestudios
RIP Rodney, AKA @lonetreestudios
Member since December 2006
Post by lonetreestudios on Jan 18, 2011 8:56:56 GMT -5
I will throw my vote in for #1, but either way, that is a very nice piece!
Rodney
Post by frane on Jan 18, 2011 9:16:01 GMT -5
I really like #2 best but no matter which way you turn it, it will be beautiful because it is just that great of a stone! You did a wonderful job on it! Fran
Post by mohs on Jan 18, 2011 9:24:01 GMT -5
Perhaps, the pattern of the agate waves can give a clue? I lean towards the first pix being the top Pretty neat-- either way Ed
Post by texaswoodie on Jan 18, 2011 9:52:09 GMT -5
I buy my Connundrum at the Rock Shed Nice cab! Curt
Post by mohs on Jan 18, 2011 9:55:58 GMT -5
lol ! your ruby in rough Curt!
Post by fishenman on Jan 18, 2011 11:55:31 GMT -5
I think number one. You say that it's the one you like so go with your gut and you can't do wrong.
Post by Hard Rock Cafe on Jan 18, 2011 13:38:35 GMT -5
My opinion is only going to make matters worse...LOL I like #1 if you're using only gold wire, but I think it might look very nice with gold overall and silver accent wrapped around the fracture and a little extra pointing down as in #2...I don't know how to actually do that, but it's what popped into my head. Chuck
NDK
Post by NDK on Jan 18, 2011 19:23:00 GMT -5
That's a gorgeous cab Krystee. After looking at the pix several times, I think #1 looks better.
As far as polishing, do you have a drill press available? I made a polishing pad to use in a drill press, and thats all I use on my cabs. If you'd like info, I'd be glad to share.
Nate
Post by tntmom on Jan 18, 2011 20:27:36 GMT -5
I buy my Connundrum at the Rock Shed ROFL Curt!!! Chuck, I'm not sure I'm ready yet to experiment with two different color wires. But someday I will try it! As far as polishing, do you have a drill press available? I made a polishing pad to use in a drill press, and thats all I use on my cabs. If you'd like info, I'd be glad to share. Nate, I don't have a drill press but WOULD DEFINITELY like you to share your method. Outside in the old workshop there are some machines that used to be used in window and door manufacturing. Sorry if I sound really naive but I have no idea what most of these machines are and have never used them either. I think this is a lathe but it appears to have a drill press of some sort on it. Would something like this work? ~Krystee
Post by tntmom on Jan 18, 2011 20:54:29 GMT -5
Oops, forgot to mention... I think I will go with my original thought of number 1. After staring at the stone for quite some time, I think covering the fracture with wire flowing in the same direction of the bands would look pretty good. The advice came to 9 votes for #1 and 4 votes for #2. Wish me luck! ~K
NDK
Post by NDK on Jan 18, 2011 21:52:27 GMT -5
