charles kuchar
Member since November 2010
Post by charles kuchar on Jan 20, 2011 13:03:35 GMT -5
i have both on hand and do my last grind before polishing in my Lot-O vibe. i have been using the ao 500 but i don't know which 500 to use on which stones. is there any difference in them? thanks, charlie
metalartz
Member since January 2011
Post by metalartz on Jan 20, 2011 13:10:03 GMT -5
my understanding (and I well could be wrong) is that Aluminum oxide breakes and stays sharp as you use. Silicon carbide is harder an Aluminum oxide but dulls as you use it.
snuffy
Member since May 2009
Post by snuffy on Jan 20, 2011 14:03:23 GMT -5
The sc grit in the coarser stages stays sharp as it breaks down,as opposed to ao which gets rounder. In the 500 grit,I just dont know for sure,I've ordered the ao 500 by mistake and have both.I rarely use 500,interested to hear what someone in the know says.
snuffy
Post by Toad on Jan 20, 2011 16:19:15 GMT -5
What Snuffy said. SiC stays sharp, and I believe is cheaper too
Post by rockrookie on Jan 20, 2011 19:26:02 GMT -5
i have used both . to tell you the truth , i have not seen any difference in the end results . --paul
Post by deb193redux on Jan 20, 2011 23:04:02 GMT -5
at 500 there should not be much effect. IMHO the SiC is more of a FINE, while the AO is more of a pre-polish because it dulls/breaks quicker.
