aimeesrockworks
I really do look like my avatar... it kinda freaks me out.
Member since December 2010
Post by aimeesrockworks on Jan 21, 2011 18:02:45 GMT -5
I've only been running my tumbler for about two weeks (Lortone QT66) and it got me thinking... Is there any way to tell what my tumbler is eating in the power-department? The search here didn't turn anything up and I can't seem to find this info anywhere else. Maybe no one ever asks, or maybe no one really wants to know. -Aimee
Post by Toad on Jan 21, 2011 18:07:58 GMT -5
There are meters that you can pick up at the hardware store that will tell you how much energy a device is using. I don't remember what they are called. Never fear, someone will know
TumbleMeCrazy
You CRACK me up....
Member since January 2011
Post by TumbleMeCrazy on Jan 21, 2011 18:21:11 GMT -5
It's gotta be less than the average teenager.
Post by jakesrocks on Jan 21, 2011 18:38:44 GMT -5
I'll bet it uses less in a month, than my wife's fancy computerized sewing machine uses in a day.
Digforcrystals
Member since July 2008
Post by Digforcrystals on Jan 21, 2011 18:40:58 GMT -5
I think I read it was $1.85 a month for a 12# rotary. Not sure if I am remember right , or if my memory is right that what I read was accurate. But it was less than $2 per month.
lparker
Member since March 2008
Post by lparker on Jan 21, 2011 18:47:53 GMT -5
Kill-a-watt meter - around $21-$26 at Amazon. I've got one...haven't used it on my tumblers yet. You normally use it to amaze yourself with how much electricity you waste each month by leaving computers on, not unplugging tv's, etc.
Lee
Post by MyNewHobby on Jan 21, 2011 20:02:37 GMT -5
You know .... I never noticed any real spikes when running both my 33B and vibe .... along with the occasional WF usage.
If there was a spike.... it is minimal
As Always
Post by johnjsgems on Jan 21, 2011 20:42:17 GMT -5
The only time I noticed was the time I ran a 40 lb. HP (1/3 hp motor) for a month and bill was $30 higher than normal. The little fractional hp tumblers usually are not noticed.
Post by johnjsgems on Jan 21, 2011 20:43:51 GMT -5
Oh, and you pretty much have to be nuts. You play with rocks.
Post by deb193redux on Jan 21, 2011 23:00:24 GMT -5
the grit cost is higher than the electric cost
Post by Roller on Jan 22, 2011 0:36:08 GMT -5
lmao yeah ...ur nuts but so r we all like john says ... i never tested my tumbler but i had my neighbor help me test the kilowatts in the basement eletric co device spinner thingy and he turned on my cabbing machine with my dayton motor from my cabber and yeah i was kind of suprised at how fast it spun ...but I knew it was alot since it heats up the room after an hour n half ... but i will say my motor from the 12lb tumbler throws very little heat if any ...
aimeesrockworks
Post by aimeesrockworks on Jan 22, 2011 1:16:30 GMT -5
Oh, and you pretty much have to be nuts. You play with rocks. I think this is the winning answer!!
drjo
Honduran Opal & DIY Nut
Post by drjo on Jan 22, 2011 9:06:45 GMT -5
aimeesrockworks
Post by aimeesrockworks on Jan 22, 2011 13:03:26 GMT -5
Thanks all, this was perfect!
Post by Sabre52 on Jan 22, 2011 13:30:26 GMT -5
*LOL* I feed two monster heat pump air conditioning/ heating units. Don't think the tumbler has a lot of impact at all. Plus we have an electric co op here in Texas and my bills here are a joke compared to back in California where a single air conditioner can cost you $400 plus a month *L*.....Mel
drjo
Post by drjo on Jan 22, 2011 15:51:08 GMT -5
Ya, but you can't get one o them californee tans in Texas ;D
Post by Sabre52 on Jan 22, 2011 16:03:59 GMT -5
Nah *L* in Texas what the fire ants and chiggers don't get, ya get all burned up like a hunk of ole boot leather....Mel
Post by quartz on Jan 23, 2011 10:39:24 GMT -5
The generic name is "load meter", kill-o-watt is one brand. Lowe's [mine was $30] and likely Home Depot sell them too. Here in Oregon, libraries are stocking them for checkout, of course, they started this after I bought one. They read out in either watts used or amp draw. Your light bill should tell you what the power rate is per kwh. [1000 watts for 1hr.]
