fmelvis
Member since November 2010
Post by fmelvis on Jan 28, 2011 8:28:53 GMT -5
I've been working on my rookie batch for about 7 weeks now, and most of the rocks are shaping up nicely. A closer look at the surface shows very tiny bumps. Not pits by any means, just not super smooth.
Will the 120/200 grit stage smooth out the surface or do I continue with the rough until totally smooth? I was going to use a fair amount of plastic beads during this 2nd stage to combat chips. Do I really need to use small gravel as well?
Frank
keystonecops
Member since October 2010
Post by keystonecops on Jan 28, 2011 8:58:41 GMT -5
Im still fairly new at this, but I use 60/90 for the 1st coarse run. In my little 11/2lb Lortone its been takn bout 7 to 8 days to smooth. I think I need to quit bein so impatient an give er nother few days to really smooth it out. Later Clyde
Post by parfive on Jan 28, 2011 12:13:02 GMT -5
Frank – Continue with 60/90 until they’re shaped to your satisfaction, then . . .
Skip 120/220 entirely – waste of time.
At the end of a week in 60/90, that grit is broken down WAY beyond 120/220, so why go back and scratch ‘em up again? Just go right to 500.
Rich
Post by Sabre52 on Jan 28, 2011 12:31:14 GMT -5
Like Rich says, if you run longer in 60/90 you can skip the fine grind step. Those bumps though are an indication of undercutting. You probably have a mixed hardness stone so the softer stuff grinds away more than the harder sections leaving those bumps. That problem may not be solvable in a tumbler like it is on cabbing wheels. You really need a homogeneous smooth surface for a good mirror polish.....Mel
Post by rocklicker on Jan 28, 2011 20:05:02 GMT -5
Good advice! Something to remember. Steve
Post by gr on Jan 28, 2011 20:09:49 GMT -5
Learned something myself ! Thanks Rich and Mel
Gary
Post by stefan on Feb 2, 2011 20:49:59 GMT -5
See now I total disagree with skipping 120/220 step. I do agree that you need to run 60/90 until all issues are ground out. Sometimes I'll run stuff in course for several months
Post by Jack, lapidaryrough on Feb 2, 2011 21:45:08 GMT -5
If your running material for several months, Then you should start of with 40/70, Our do a lot of pre-shaping.
40/70 wont break down, Like 60/90 & 80 grit. after a three week run.
In large tumblers with the weight as ( Parfive ) Said the grit breaks down to a fine grit.
Skipping 220-grit on the 3-F or 400 grit is a time saver.
And saves on Barrel ware. Wallet is a bet fatter, From cost savings.
Post by stefan on Feb 3, 2011 10:00:39 GMT -5
Hehehe Ask a 100 tumblers about the correct stages and get a 100 answers!! Everyone has there own method and formula. THe key is to try new things and keep track of what works and doesn't work for you!
Post by quartz on Feb 11, 2011 20:59:45 GMT -5
For really rough, craggy quartz [we call it "hillside" agate] we use 16 grit to rough it down. Two weeks generally works great, then to 80 grit and so on. An ancient rockhound friend, who also had a shop in Milwaukee, OR for several years said "16, really". Then he tried it, and liked it. We run 1 3/4 & 5 gallon rotaries.
Post by Sabre52 on Feb 11, 2011 23:02:52 GMT -5
I know this is different from what a lot of you think but I find the super coarse grits like 40/70 for me at least, don't cut and shape as well as the 60/90. When I check the barrels after a week or so in 40/70 a lot of the grit has sunk to the bottom while 60/90 sticks to the stones and seems to work better. A t any rate, for me, the stones seem to round and smooth better and faster with the 60/90....Mel
Post by Jack, lapidaryrough on Feb 11, 2011 23:34:32 GMT -5
another great tumbler grit is old grinding wheels, broken down to 1"-minus. I go to the machine shop around my area. i get them free our $1.00 a piece. most of the shops use 80 & 120 grit wheels. The 220 grit wheels i use to re-dress the saw blades and the diamond wheels, i never well use a fire brick or red brick. Obsidian blue sheen or 220 grit. Red brick & fire brick cut`s down the kurf on a diamond blade.
Jack
