spokanetim
Member since October 2009
Post by spokanetim on Feb 3, 2011 20:46:37 GMT -5
Ok, did the needed modifications from my dream of a 14" water saw back to a oil saw. I bought a Little Giant pump and set up the circulation with light weight ag hydraulic fluid. Got my new 1 hp sealed ag Leeson Motor from QC Supply, best price by far I could find on the internet. I'm still just using the rock hammer as added weight till I buy something better. Anyway, I got it all put back together and started up the pump. Surprisingly hydraulic fluid get's pretty thick when it's 20 degrees outside! After a few min the oil was flowing onto the blade and I reconditioned the blade with a red brick like suggested. Cut the brick like a hot knife threw butter. Next onto couple harder stones and it worked like a dream. Made nice cuts at a decent rate. Cut a few slabs before I started freezing and put it away. Looking forward to cutting more in warmer weather. Thanks for the help and suggestions Maury Mountain Moss Owahee Picture Jasper Tim
Post by Roller on Feb 3, 2011 21:00:37 GMT -5
pretty rocks need a good cuttin ..
metalartz
Member since January 2011
Post by metalartz on Feb 3, 2011 22:03:07 GMT -5
looks good
NDK
Post by NDK on Feb 3, 2011 22:21:37 GMT -5
I read the other thread with interest, but had nothing to add that would help, so I didn't say anythnig.
It's good to hear it didn't turn into a 600 dollar door stop, Tim!
Nate
spokanetim
Post by spokanetim on Feb 3, 2011 23:58:29 GMT -5
Thanks guys, Nate I was worried myself. Now I'm $800 into it (the new motor) with a credit for $100 worth of quality rough from the guy I bought the saw from (for returning the motor he gave me). It's a brand new saw top to bottom so I guess I'm still doing better than buying a new 14" $1600 HP without the stand or blade.
Post by frane on Feb 4, 2011 12:00:16 GMT -5
Sweet slabs! It is great to see the saw is now in business! I know what you mean about the cold. You can only take so much before you have to put the saw away and go in! Fran
juzwuz
Member since April 2010
Post by juzwuz on Feb 4, 2011 15:49:03 GMT -5
Hi! I was told to dress a diamond blade with obsidian or a fire brick. Does a red brick work the same as a fire brick? I picked up a fire brick from Home Depot for around $1.50.
Post by rockmanken on Feb 4, 2011 17:10:58 GMT -5
Tim, all you need now is kitty litter to soak the oil off the slabs. Juzwuz, fire brick is better.
spokanetim
Post by spokanetim on Feb 6, 2011 18:20:07 GMT -5
Just wanted to add this little safety note to those of us who aren't very mechanical. Yesterday as I was standing right next to the saw happily watching it cut a slab, pretty much from where this picture was taken but closer. Luckily or by the grace of God I noticed the main polley on the saw blade rapidly start sliding off the shaft. I pulled the plug just before it came off as the motor stopped. Had it happened at full rpm it could have a the least destroyed the saw at the worst injured or killed me standing there. The locking screw had come loose and spun out of the polley. Today I spent $3.00 for a little bottle of thread lock, something I would have never thought to do or even knew about. tim
