Post by stefan on Feb 28, 2011 10:54:39 GMT -5
My trusty Model T would not start over the weekend. I finally got the shaft turning and that poor thing was just a screaming (with no load on it). I pulled out my drill and drilled out those annoying little rivet covers. Well after a good cleaning I discoved the problem. The front shaft bushing (not really a bearing)was wrapped with 5+ years of accumalated dust and dirt. I spend the better part of an hour cleaning it all up and giving the moter a once over. I found some small nuts and bolts and replaced the motor cover/ motor mount and fired it up. Spins like its new. This was my first real tumbler that started me on this strange adventure (obbsession) and it was nice to see it still has some kick left in it! Now I need to figure out of fixing those 3 CE tumblers I have is worth the effort. (FYI the Model T is the tumbler featured in my avatar)
meta99
Ohio Flint Ridge flint
Member since October 2010
Post by meta99 on Feb 28, 2011 13:27:41 GMT -5
When I first read this, I thought you had a Model T car!!! I should've learned from past posts to read CAREFULLY so you know what people are talking about! ("My wifi is screwed up" vs "wife") I thought "Why is he drilling into a car?!"
Post by rockrookie on Feb 28, 2011 15:49:59 GMT -5
glad that you were able to solve the problem . this hobby is turning me into a mechanic , too . haha!! --paul
drjo
Honduran Opal & DIY Nut
Post by drjo on Feb 28, 2011 18:26:21 GMT -5
I'm going out on a limb here and going to suggest you shorten you maintenance schedule ;D ;D ;D As far as the CE's go, whathave you got to loose, you can only make the better Dr Joe .
snuffy
Member since May 2009
Post by snuffy on Feb 28, 2011 18:41:50 GMT -5
Call Shawn,I'm sure he has 3 lortone motors on hand. snuffy
Post by Jack ( Yorkshire) on Mar 1, 2011 3:49:49 GMT -5
Regular maintance is a good idea
Remember these little critters are sometimes running 24/ 7 and 365 days a year
How would you like it if no one gave you a drink of oil !! or changed your - - - - - - -
jack Yorkshire UK
drjo
Post by drjo on Mar 1, 2011 16:18:41 GMT -5
Personally, I would be a very squeaky tumbler ;D
Post by stefan on Mar 2, 2011 9:33:26 GMT -5
Funny thing is I'm pretty strict on maintence- But that pesky motor cover/ mount on the Model T just make routine maintence nearly impossible (up until now!) I will take my hat off to the people at Thumlers (and Fasco- the motor manufacturer) they do build some pretty durable machines! As for the CEs I only have 2 VERY worn barrels (like so worn the ends are more bicycle patch than barrel). Maybe I'll offer the whole lot up to someone on here- perhaps they can breath some life back into them as I just don't want to mess with these! Oh and Meta99- LMAO- yea I miss read that wifi post too! First thing I thought was OH NO Sands got married again!
