mia
As you travel on thru life, whatever be your goal. Keep your eye upon the donut, not upon the hole.
Member since January 2011
Post by mia on Mar 1, 2011 23:50:08 GMT -5
Been admiring all the ingenuity of home made tumblers here... anyone ever make a tumbler from one of those home rotisserie ovens? or a BBQ rotisserie? Just curious.
Mia
chromenut
Member since December 2009
Post by chromenut on Mar 1, 2011 23:52:48 GMT -5
Hmm... kind of making me hungry....lol....not sure I want my rocks heated up though...hhaahahahahah
Post by deb193redux on Mar 2, 2011 0:12:16 GMT -5
you either direct drive the barrel rotation, or the roller rotation, or the motor turns a drive pulley that turns a driven pulley on the roller.
barrel should turn at about 40-60 RPM. typical rotisserie speed (3-8 RPM) does not work for either of the direct drives, and is way too slow for the belt.
but, you could get a surplus gear motor that went about 40RPM and build a unit. might not cost much more than a rotisserie motor if you get a good surplus deal
mia
Post by mia on Mar 2, 2011 0:21:25 GMT -5
Hey Daniel is that you? Was working on a cab from some of the picture jasper you sent me last year today and was thinking kind thoughts...
mia
Post by mia on Mar 2, 2011 0:25:55 GMT -5
OK then rotisserie too slow... I have a motor with a gear box. currently has a tire attached for the barrel... someone's home made tumbler. Okie engineering . I think I want to convert it to some sort of shaft/pillow block arraingment for barrels. Will have to think about it for a bit. Mia
Post by deb193redux on Mar 2, 2011 13:58:48 GMT -5
it is me. let me know if you want to chat about tumbler building project. I might have soem spare rollers and/or some old Lortone 6lb barrels. Can't decide what I want to do with them.
what is the RPM out of the gearbox? is it turning the barrel? or turning a roller that turns the barrel.
Making a 45-deg angle design like an open cement mixer has always made a lot of sense to me. Could be direct drive, or still use a belt like Covington model.
mia
Post by mia on Mar 2, 2011 23:49:43 GMT -5
Hey Daniel, the gearbox turns the Tire directly, it's an old airplane tire, LOL. I dont know the speed. I will have to take some pics for you to see tomorrow. It's a crazy looking thing. I thing the motor would be better utilized turning a roller where one could have 2 or three small barrels going at once.
Mia
Saskrock
Member since October 2007
Post by Saskrock on Mar 3, 2011 0:55:05 GMT -5
Hold on don't rule out the rotisserie. If it goes at 5 rpm and you put about a 50" pulley on the rotisserie and a 1" pulley on a 1" drive shaft on a 5" barrel it will go about 50rpm. Just picture this in your basement. ............................................................................. yeh ok maybe a different motor would be better. to be serious try a furnace motor. Usually heating/plumbing shops will let you pull a old one out of the scrap pile for free or next to it. Might even get some pulleys. Just make sure its not a air over motor or it will overheat. Generally the ones with a belt are what you want. I have made a couple of tumblers with these.
Post by Jack ( Yorkshire) on Mar 4, 2011 5:16:00 GMT -5
NDK
Post by NDK on Mar 5, 2011 22:42:36 GMT -5
It doesn't get much eassier than this LOL!
Nate
CallMeShane
Member since August 2010
Post by CallMeShane on Mar 5, 2011 23:10:22 GMT -5
It doesn't get much eassier than this LOL! Nate As a coin collector,that frightened me.
drjo
Honduran Opal & DIY Nut
Post by drjo on Mar 6, 2011 8:11:53 GMT -5
Post by Jack ( Yorkshire) on Mar 7, 2011 4:43:52 GMT -5
Nice music
Post by catmandewe on Mar 8, 2011 1:11:21 GMT -5
When I was in Quartzsite a rock hound wanted to sell me a home made tumbler he didn't use any more. I told him to bring it by and I would take a look at it. I loved it! I put three 5 gallon buckets of rough in it and turned it on and I only had it about 10% full. I put it up for sale, ( I was hoping to take it home with me), it sold the next day to a vendor. I did take a picture of the beast before it left though. It had a gear reduction motor and a chain for the drive I shoulda kept it! Tony
Post by quartz on Mar 8, 2011 10:35:53 GMT -5
What was the asking/selling price of the big homemade, curious about this one. Looks well thought out.
Post by catmandewe on Mar 8, 2011 20:15:37 GMT -5
I sold it for $550.
Post by deb193redux on Mar 8, 2011 23:00:45 GMT -5
good price considering the cost of a 40lb unit
charles kuchar
Member since November 2010
Post by charles kuchar on Mar 9, 2011 14:53:21 GMT -5
jack, terrific links on hints to work with the rocks and stones. thank you... charlie
Post by deb193redux on Mar 9, 2011 15:55:58 GMT -5
It doesn't get much eassier than this LOL! Nate this one might be simpler, but I think the drill motor will burn out under continuous duty:
charles kuchar
Post by charles kuchar on Mar 9, 2011 16:41:02 GMT -5
pretty small opening for the rocks. i would have to modify it to get my big rocks in there. headed to the big rock show in kc early tomorrow... charlie
