jody
Love our country because it Loves U.S.
Member since January 2011
Post by jody on Mar 9, 2011 20:31:12 GMT -5
I have a problem I can not get passed doing rings :blush: Im just stuck on them. Attachments:
jody
Post by jody on Mar 9, 2011 20:31:53 GMT -5
A side view Attachments:
NDK
Post by NDK on Mar 9, 2011 20:37:54 GMT -5
Cool!
Nate
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Mar 9, 2011 21:50:31 GMT -5
I see what is happening,I think. It looks like your wires are shifting when you turn them, you have to make sure that they all stay together. The distance from the binding wires to the bottom of you cabochon is where, I think, the problem lies. If you can make that part tighter, you will have better results.
I hope that I have not discouraged you because it does seem to turn out ok and you do good work. I know that there are times that I just have to put it down for awhile, then I can look at it and say hello, why didn't I see that earlier.
Good luck, Tammy
jody
Post by jody on Mar 10, 2011 1:04:00 GMT -5
Thanks Tammy I agree lol
Post by FrogAndBearCreations on Mar 10, 2011 8:49:37 GMT -5
looks like your using round wire for the ring shank and that is where you will get the shifting issue. Try using square wire for the ring shank and binding it with the same gauge square wire instead of half round at the two sides.
The ring looks good!
jody
Post by jody on Mar 10, 2011 11:22:28 GMT -5
Thanks frog n bear I will try that.
