CallMeShane
Member since August 2010
Post by CallMeShane on Mar 14, 2011 19:39:00 GMT -5
my slant cabber www.hitechdiamond.com/product.php?productid=17520This here is the mount for the discs,it's a half inch arbor with a 1/4-20 thread. That little nub of an arbor is only 2mm high. What I'm trying to figure out is if I can mount a groove bit like the one from Gryphon onto this. I'm also not really sure what all I would need to do it as far as parts go. I already have an idea for a simple work surface I can pop into place and remove easily,basically a wood frame covered with some sheet metal. I'm having trouble finding the inside diameter of the Gryphon groove bit also. Any idea's on why this might or might not work?
Post by deb193redux on Mar 14, 2011 21:33:39 GMT -5
it is more like 1/4 - definately not 1/2" ID. You might be able to have one of those grinder bits bored out, but the Gryphette goes on sale for <$50 usually 1 or more times a year. Balanced against the cost of boring, vs the benefit of an extra unit and dedicated groover ... I would just buy a Gryphette grinder.
spicer m
Member since October 2008
Post by spicer m on Mar 14, 2011 22:09:25 GMT -5
Take a 1/4" bolt and cut the hex head off. screw a 1/4" nut onto the bolt threads (to be used as a lock nut). screw 1/4" bolt into end of shaft and lock nut to end of shaft. mount grove tool on 1/4" bolt Mike
