Billy
Member since March 2004
clean
Mar 2, 2004 20:48:43 GMT -5
Post by Billy on Mar 2, 2004 20:48:43 GMT -5
can anybody give me a hint about cleaning between grits and how should I clean to get all the polish off
clean
Mar 2, 2004 21:31:14 GMT -5
Post by docone31 on Mar 2, 2004 21:31:14 GMT -5
The polish is like a grit. It comes off with a wash. Cleaning between grits. I usually run the stones through clean water in a strainer. With picky stones, I will run a clean water bath with borax for one day. I have heard of folks using brushes and really putting labour into it. I have not found that neccessary. Experience will dictate the approach you use.
Banjocreek
Member since March 2003
clean
Mar 2, 2004 23:39:57 GMT -5
Post by Banjocreek on Mar 2, 2004 23:39:57 GMT -5
Before I got a seperate barrel for each step, I would rinse the stones and the beads with water, then put them back in the barrel a run them for a few hours with a tbls. of cascade, then rinse them again. The beads would go in a ziplock bag that I would label with whatever grit they ran with. Then I would put in new beads and fresh water enough so just the tops of the rocke were exposed, and add the next size grit and repeat the process in 7 days. I'd add more beads and a little ivory soap in the last two stages.
MichiganRocks
"I wasn't born to follow."
Member since April 2007
clean
Mar 3, 2004 9:49:25 GMT -5
Post by MichiganRocks on Mar 3, 2004 9:49:25 GMT -5
I agree with Doc about the brushing. I've spent hours examining rocks with my jewelers loupe and brushing with a tooth brush, and results were no different than if I just put them in a strainer and rinsed them thoroughly. My next load that comes up is going to get run with borax to clean. The more I read up on borax, the more I think that Doc has the right idea with it as well.
Ron
RiverOtter
Member since January 2004
clean
Mar 3, 2004 10:19:42 GMT -5
Post by RiverOtter on Mar 3, 2004 10:19:42 GMT -5
The borax is great stuff. I recently bought some and started using it to run the rocks in between grit stages. Saturday I removed my rose quartz from the medium grit and rinsed. I noticed one stone in particular that had a deep crevice in it and grit was present there. I put the stones back in the barrel with borax and ran for a day. When I pulled it on Sunday the stone with the grit in the crevice was completely cleaned. To me it's well worth the extra day.
Otter
SirRoxalot
Member since October 2003
clean
Mar 3, 2004 16:35:10 GMT -5
Post by SirRoxalot on Mar 3, 2004 16:35:10 GMT -5
I double wash - and always find some grit coming out in the second rinse. I also have to confess that I spend a lot of time grading and using a nail brush on the stones, but I'll probably grow out of that habit. How much time you have to spend cleaning relates to the quality of the rough; if it's full of pits and cracks, lordy, you've got to work on it. If you can bring the rocks to a nice polish without having to scrub them, goodonya. I'd say the one time you gotta have them clean is before you start the polish - carried over grit is probably the main cause of poor polishing.
Billy
clean
Mar 3, 2004 19:56:11 GMT -5
Post by Billy on Mar 3, 2004 19:56:11 GMT -5
thanks for all the feedback I have a vib18 and it holds a lot of rocks I clean with a toothbrush and it takes a while but I will try the borax this load
llanago
clean
Mar 4, 2004 9:36:34 GMT -5
Post by llanago on Mar 4, 2004 9:36:34 GMT -5
Where do ya'll find Borax? I have looked in every grocery store I have been in and at WalMart, but there is none to be found! Am I just not looking the right places or am I gonna have to order some online?
MichiganRocks
clean
Mar 4, 2004 9:40:23 GMT -5
Post by MichiganRocks on Mar 4, 2004 9:40:23 GMT -5
Hi Ilana. I've found it in the grocery store (A&P) and in KMart with the laundry detergents. Look for "Twenty Mule Team Borax".
Ron
