Post by Donnie's Rocky Treasures on Apr 5, 2011 12:07:36 GMT -5
I have a MK-145. I went through my first MK-303 way too fast so I bought some blades from someone who has blades from India (Sachi) & now from Lopaki (Chinese) The Sachi is the same thickness as the 303 .20, even though the Sachi is a heck of a lot more flexible that the 303. The one from Lopaki is .008 a little less flexible than the Sachi. Problem is the 303 is nice & snug in the saw, the other two are not & I can not tighten them down. They slip & when I would try to cut the blade spins until I push the slab against it - quits spinning. I hope like heck this makes sense! dunno28 Tile blade is fine, the 303 is fine, seems like these are too thin but that really shouldn't make a difference, right?
Post by jakesrocks on Apr 5, 2011 12:19:19 GMT -5
Donnie, is there a flange washer between the nut and blade ? I'm not familiar with that saw, but you might want to put a flat washer between the flange washer and nut. That should make up the difference in thickness.
Post by FrogAndBearCreations on Apr 5, 2011 13:58:41 GMT -5
if this is for your tile saw you will need to use a washer with the thinner blades. I bought some $5.00 blades from Harbor Freight that are much thinner than the regular blades for my tile saw and had the same problem so I just hunted a washer that made the difference in thickness needed to tighten it correctly. I used a fender washer that was just right with small bit of filing to get it to fit the arbor.
I also had to make a little bushing to fit the blade for the saw arbor. I just filed a washer that was the correct diameter ouside but not inside, to fit along with the spacer washer.
Post by jakesrocks on Apr 5, 2011 14:15:43 GMT -5
You might try various sizes of spark plug washers for blade bushings.
Post by stefan on Apr 6, 2011 11:39:03 GMT -5
Also make sure the arbor washers are on in the correct order. On my saw they are slightly different and the inner one has to go on first. If I reverse the order the blade won't tighten down properly.
Post by Donnie's Rocky Treasures on Apr 6, 2011 11:47:21 GMT -5
Ok, thanks. Found one to use last night & got some preforms cut. Need to make a slight adjustment as far as size, otherwise problem solved!
