juzwuz
Member since April 2010
Post by juzwuz on Apr 6, 2011 0:00:44 GMT -5
I got a box of rose quartz (thanks Kap!) and was wondering if there's a good way to cut it to try and find a star pattern? Thanks! ![](http://i1014.photobucket.com/albums/af268/juzwuz/Lapidary/IMG_0397.jpg)
Post by kap on Apr 6, 2011 7:10:54 GMT -5
Maybe Rodney(digsforcrystals) will jump in he know all about cutting Rose ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) . Keith
crystalchemy
Member since April 2011
Post by crystalchemy on Apr 6, 2011 7:58:17 GMT -5
toss a 2" chunk in the tumbler or polish a piece round. no way to tell if itll make a star other than to polish it. cant really search for stars, theyre more like a bonus we find after making a cab. all rose qtz is birefractive, like prehnite, so it has a different look than other star minerals. Most rose quartz has no asterism; S Dakota rose quartz often does, other star rose locales are Vietnam or Madagascar.
Digforcrystals
Member since July 2008
Post by Digforcrystals on Apr 6, 2011 8:13:50 GMT -5
I operated the Hogg Mine for 5 years and while I know a whole lot about specimen mining , I know very little when it comes to cabbing. All of the transparent hogg mine rose quartz shows asterism to some degree with some pieces being better than others. There is a trick using a drop of honey or Karo syrup that is used to find the best orientation. Other people here will do a much better explanation on that method than I can. ![](http://www.dixieeuhedrals.com/images/Hogg_mine_star_sphere.jpg) One of my better hogg mine spheres. Please note this is backlit and the star shows many times better in "transmitted" light than in "reflected" light.
rocpup
Pink Limb Iris
Member since March 2011
Post by rocpup on Apr 6, 2011 12:39:10 GMT -5
Years ago there was an article in a Lapidary Journal telling how to orient a star in quartz. It was complicated in that you had to orient the x and Y axis using polarized lenses from sun glasses. It was a long time ago and that is about all I remember. I am sure the info is out there. Maybe some one will help. Near Yuma there is a deposit of quartz that is said will star. I have some some day might try it out. Another solution would simple make a very high dome and see where the star is and go from there.
juzwuz
Post by juzwuz on Apr 6, 2011 14:00:31 GMT -5
Thanks for the tips! Kap mentioned that the rose quartz was from the Hogg mine and could show a star if cut properly. I'll slice a couple of pieces to try and isolate some of the more transparent areas of the quartz and then go from there.
Post by Toad on Apr 6, 2011 15:22:53 GMT -5
Good luck. Look forward to seeing what you get out of it
Post by Roller on Apr 6, 2011 23:29:35 GMT -5
I never cut one or tried but advanced cabochon cutting by jack r. cox 1986 has 1/3 of the book written about orientating a star and plenty tricks listed from waht i remember reading like with using a lightbulb and so much other stuff that it takes up a third of the book and the book is only 6$ ... maybe look into that ... Greg
Post by christopherl1234 on Apr 7, 2011 0:32:45 GMT -5
Digforcrystals
Post by Digforcrystals on Apr 7, 2011 7:26:19 GMT -5
Now that's an awesome star.
I think for the honey, you use one drop that forms a bead. Supposedly you can shine a light and see a star , if you do , that is where the dome should be. But if you dont see a star you should rotate the piece of stone and re-test.
Not sure if this is exactly right and i was hoping someone that had actually used this method would chime in.
Post by tanyafrench on Apr 7, 2011 8:30:20 GMT -5
Christopher those are some beautiful stars. Great job.
Tanya
