Post by krazydiamond on May 4, 2006 20:00:01 GMT -5
shape your stones, cpdad, until you have enough to move onto the next run. i am presuming you are working with one tumbler? i run three (3) pounders two weeks to get enough to move into one barrel for a 120/220 grind, i have gotten picky and still not as picky as some. always depends on your rough, the MOH and what your desired end result IS. i make a lot of magnets out of the "almost" perfects. if your son is into scouts or similar, maybe he can raise some money that way? i get my magnets from K and J magnets: www.kjmagnetics.comgood luck, KD
Post by Bikerrandy on May 4, 2006 20:16:30 GMT -5
They lost almost 50 percent? If you're pre-shaping soft rocks (like hardness of 5 or less), then I'd only tumble them for 3 or 4 days. (I'm guessing that these weren't agates) Pre-shaped agates should be able to go 7 days or more in the coarse grit.
Post by cpdad on May 4, 2006 20:31:05 GMT -5
actually it was hematite...and i preground them to the point that there wasnt any sharp edges or pits....all was ground totally smooth with an 80 grit silicone carbide wheel...all defects were removed before i put them in the tumbler.
jrtrio
With10 tumblers tumbling the sound is so delicious!Send me more of those little red fellas, please?
Member since February 2006
Post by jrtrio on May 4, 2006 20:39:18 GMT -5
I'm thinking that next time you might want to try moving them on to the 120/220 stage instead of any time in the coarse grit. I'm betting that you may have to run them just a tad longer but they won't lose as much mass and they will smooth on up like you want. But, remember that with some stones you're going to lose up to 2/3 of their mass no matter what you do. But, do what I do and keep a log of the stones you do so when you get another bunch of them you'll know what you need to do to get the best out of them! Good luck!
Zoran
Member since September 2005
Post by Zoran on May 5, 2006 4:42:53 GMT -5
I agree with jrtrio. My experience exactly.
Post by stefan on May 5, 2006 9:50:41 GMT -5
YUP on the skipping the course- I pregrind a lot of stuff- Sometimes I even buzz it on the 220 belt and toss it into 500- If your using an 80 grit wheel- and you like the appearence of the stone- go right to 120/220 grit!
Post by Cher on May 5, 2006 10:33:44 GMT -5
actually it was hematite...and i preground them to the point that there wasnt any sharp edges or pits....all was ground totally smooth with an 80 grit silicone carbide wheel...all defects were removed before i put them in the tumbler. You already did the work of the coarse stage then so skip that step and start them in 120/200. How'd you like the mess they make when you were tumbling them?
Post by cpdad on May 5, 2006 17:49:40 GMT -5
ya it made a mess..even after 120/220..it made another mess...i can see why to tumble by itself...i put them in 60/90 to start with because we wanted really nice rounded edges....and i ws under the impression that 120/220 wouldnt do any shaping...even though i pre ground the rock...it still had a few places where straight lines met..i didnt take the time to round every corner...maybe i should have said that earlier
Post by cpdad on May 8, 2006 18:00:06 GMT -5
ok...im back at it again...i preground a few more peices...this time some of the savannah river stuff cp found...theres about 15 peices of the river agate/chert...and a few peices of amythyest...in the pic they are in the middle on the left is some small peices of amythyst...and garnets....on the right is larger peices of tumbling rough....same agate/chert...along with some larger peices of amythyst (pre tumbled)...some tumbled filler rock...and a few large peices of pink granite. now what would you all do....all im experimenting with now is the preground peices. can i throw it all in 120/220...and expect the preground peices to be ok with all of the rough? or should i just wait until i have enough that has been thru 60/90...and needs to go back thru it again..and fill it with that? i know the pic isnt good...i only had a sec to take and download it..the pic shows what i had in the 3lb tumbler...i dumped it out to ask this question before going any further. ![](http://i31.photobucket.com/albums/c386/fittycents/slabs012.jpg)
