learn2turn
Member since February 2011
Post by learn2turn on Apr 11, 2011 19:39:14 GMT -5
Newb question:
I noticed that borax is very gritty like fine sand. If you are burnishing with a few Tbls of borax and a spray of water, it obviously can't all dissolve.
Does it not scratch the stones because the borax crystals are much softer than stone?
Post by Hard Rock Cafe on Apr 11, 2011 21:44:24 GMT -5
It dissolves very easily in water. I use more than a spray when I burnish in my vibe. I assume that since you mentioned a "spray" you're using a vibe tumbler?
Post by Sabre52 on Apr 12, 2011 8:06:16 GMT -5
Yeah, Borax is soft ( mohs 2-2 1/2) so it won't scratch your stones. I stopped using it and switched to Dreft as a burnish though, due to the disposal problems. Borax is a powerful herbicide so you really have to watch where you dump your tumbler wastes to avoid killing your plants while Dreft is harmless to the environment.....Mel
learn2turn
Post by learn2turn on Apr 12, 2011 11:51:20 GMT -5
Thanks for the tips on Dreft. I'll see if I can find it. I usually just dump used slurry in the woods behind my house and I don't want to kill all the plants.
Post by Sabre52 on Apr 12, 2011 18:14:32 GMT -5
Dreft is a powdered soap you find in the baby dept in stores. It's a great burnish. Can't remember who but someone here put me onto it....Mel
MikeS
Post by MikeS on Apr 13, 2011 8:57:57 GMT -5
I've never had good luck with Borax, I use Ivory bar soap shavings instead....
