habbie
Member since February 2011
Post by habbie on Apr 14, 2011 16:59:01 GMT -5
I was cutting a rock with my brand new covington 10" saw and the rock slipped out and completely ruined the blade!!!!!!!!!!!! Now what is the best blade that I can replace it with? I trust you guys for the best info
Post by Sabre52 on Apr 14, 2011 17:34:56 GMT -5
The MK303 and the MK301 Gem king are both great blades and Barranca makes very similar blades too, Eloxite has the MKs on sale right now 303 at $68.40 301 at $95.96. John at JS gems who is a member here may be able to beat those prices so I'd check with him first but I buy from Eloxite a lot and they do have good prices. I'm running a 303 on my Covington 10" right now and it is a really nice blade.....Mel
habbie
Post by habbie on Apr 14, 2011 19:56:31 GMT -5
ty sabre52 will check them out in the morning
Post by Rockoonz on Apr 14, 2011 22:54:22 GMT -5
The Barranca 303 is my favorite for slabbibg.
Lee
Post by Roller on Apr 14, 2011 23:14:25 GMT -5
whats the difference between 303 and 301?
meta99
Ohio Flint Ridge flint
Member since October 2010
Post by meta99 on Apr 15, 2011 6:45:53 GMT -5
whats the difference between 303 and 301? Well, duh Greg! TWO!!!
rocpup
Pink Limb Iris
Member since March 2011
Post by rocpup on Apr 15, 2011 8:48:43 GMT -5
Habbie A rock coming out of your vice will damage a expensive blade also. Maybe you need to get cheaper one until you learn to clamp your rock. If your blade is just bent or kinked a little hammer work might get it to cut again. Maybe just for trimming. What have you got to loose. Rocks coming loose does happen to us all. Last week sent me to the hardware store for a new drive belt because the rock turned and clamped the blade and burnt the belt into. After every cut I grab the rock in the saw and give a tug. If it moves I look to see why. Sometimes you saw through a fracture and loosen the vices grip. Welcome to the crowd. Don
habbie
Post by habbie on Apr 15, 2011 8:56:28 GMT -5
ty for all the replies, I check the rock when I clamp it down but something gave on this one. I would hate to use a cheap blade and ruin the rock when I cut it, think I will do it the stupid way and go with the good blades.
rocpup
Pink Limb Iris
Post by rocpup on Apr 15, 2011 9:13:23 GMT -5
Buying a good blade certainty is not stupid and a cheap blade is not going to ruin your rock unless your are cutting something like opal or lapis or some other expensive rock that you might want to use a thin blade for. From what I have seen high dollar blade will last longer and MAY give you more cuts for your dollar. But they get kinked too.
Post by Roller on Apr 15, 2011 10:34:48 GMT -5
lol meta ur a funny guy ! i looked it up ... The MK-301 provides superior cutting performance for hard materials such as agate, petrified wood or jade. and the 303 is for less material loss and speed ...
Post by Sabre52 on Apr 15, 2011 11:51:59 GMT -5
MK 301 is actually a thinner kerf than the 303 ( .040 as opposed to .050 for the 303) so it uses less rough but it has a special hardened core for more blade strength and less dishing plus it has a very aggressive edge design and more depth of diamond on the edge. The 303 which I'm using right now does cut well and makes very very smooth cuts.....Mel
Post by johnjsgems on Apr 15, 2011 13:30:04 GMT -5
Well, if you look up the MK and BD blade part numbers you will find they are the same blades. The 301 (new style) has a taller rim and wedge shaped segments in the core so it will out perform the 303C. A 303C .040" blade has the same core and thickness as the 301. Same factory in Korea makes both the 303 and 301. Both work very well in 10" saws.
Post by Sabre52 on Apr 15, 2011 18:50:17 GMT -5
Hmm just going by my Eloxite catalog on the blade thickness measurements. I've not used a ten inch MK 301 but the catalog says the 303 is thicker. Not that .010 matters much in the big scheme of things *L*. Ran my new saw again for a couple of hours after horses today and it is really cutting nice and on hard materials too....Mel
Post by johnjsgems on Apr 15, 2011 19:00:25 GMT -5
10" 303C is available in .032", .040", and ,050". 301 only comes in .040". I wouldn't use the .032" in a power feed saw but always did on my hand feed saws.
Post by Sabre52 on Apr 15, 2011 19:16:33 GMT -5
Yeah, I've never used a blade that thin except for trimming. I always figure thicker is better when using the power feed. Excellent power feed on that Covington ten incher.....Mel
Post by stonesthatrock on Apr 15, 2011 19:49:50 GMT -5
we use the cheap chinese blades, that way when i bend one i don't feel so bad... lol mary ann
