colliel82
Member since November 2007
Post by colliel82 on Apr 14, 2011 17:44:30 GMT -5
Probably a dumb question, but do you need to orient rainbow obsidian a certain way to get the best slabs from it?
Post by FrogAndBearCreations on Apr 14, 2011 18:18:46 GMT -5
You do if you want that rainbow to show on your cab.
Post by gr on Apr 14, 2011 20:51:49 GMT -5
Diane, there is an explination here in more than one of these threads on how to correctly position the piece for cutting. If I can find some, I will post back here.
gr
Post by tntmom on Apr 14, 2011 21:04:09 GMT -5
Post by Woodyrock on Apr 15, 2011 1:06:38 GMT -5
Diane: There are two strategies on cutting for best colour. Fiorst one, you cut at about 15 degrees to the place of colour. This will cut through the colour layers giving a shingle effect of colours. The second way is to cut parallel to the colour bands, then when you dome the cab you will get the layers in rings. Both produce colour, but a wee bit differently. To get colour at all you must cut either of these ways. Just remember the colour bands are not straight lines, so each piece will be different. Woody
colliel82
Post by colliel82 on Apr 16, 2011 8:13:32 GMT -5
Thanks for all the info
