playin4funami
Member since March 2011
Post by playin4funami on Apr 21, 2011 10:36:55 GMT -5
hello! well I save and seperate my slurry after it settles in glass jars, I recently (last changeover) started adding some borax to the mix as alot of folks said it helps, I poured my slurry out for a change over yesterday and set it aside to settle out and it didn't, the whole jar just turned into a jelly like mass,is this normal? and if not what could I have done to get rock dust and water to turn into jelly? it has the consistency of jello
Post by Jack ( Yorkshire) on Apr 22, 2011 2:13:44 GMT -5
I havent had that problem when I have used Borax
I now dont bother to keep it as it is to much trouble for what you save
Jack
drjo
Honduran Opal & DIY Nut
Post by drjo on Apr 22, 2011 4:24:27 GMT -5
How much Borax do you use?
playin4funami
Post by playin4funami on Apr 22, 2011 11:50:17 GMT -5
I added 2 tbsp to a three lb barrel and about 4 drops of dishwashing soap, and tumbled for 2 weeks, when I dumped it out it poured fine, when I looked again 5 minutes later it was set up into jelly,lol. not really a big deal just wondered why?
Post by johnjsgems on Apr 22, 2011 14:31:49 GMT -5
Whatever you do, don't put it on your toast.
Post by Fossilman on Apr 22, 2011 16:49:05 GMT -5
Whatever you do, don't put it on your toast. Not without peanutbutter anyhow...........LOL
Post by connrock on Apr 23, 2011 9:08:22 GMT -5
I'm SURE there's someone here who knows the right answer but my guess is that mixing borax with dish soap instead of powdered laundry soap may have something to do with it? Maybe I'll mix up a batch of each to see what happens!
connrock
playin4funami
Post by playin4funami on Apr 23, 2011 19:01:46 GMT -5
might have to get things just right, I did the same thing on the recharge and restarted it with out the jellylike stuff happening, no biggie just thought it was odd.
