rockgirl
great state of ohio
Member since April 2011
Post by rockgirl on May 4, 2011 12:12:56 GMT -5
i don't want to take credit for cutting this but i want to use it as my avatar and can't seem to figure out how to do it...i went into photobucket and shrunk it and still i can't get it .copy and pasted it 20 times.....gggrrrrrrrrrrrrrr!! i give up~~ :help: karon
Post by 150FromFundy on May 4, 2011 20:53:35 GMT -5
Karon: I had a similar problem with the Avatar. If I remeber correctly, you are very limited on the picture size, or number of pixels. Check out the fine print on that. The other problem may be the code that you need to post a photo has to be stripped to post an Avatar. There will be one code at the beginning and one at the end that have to be deleted from the Photobucket link code. Darryl.
rockgirl
great state of ohio
Post by rockgirl on May 4, 2011 22:20:09 GMT -5
OMG!! Darryl.....that was it.....such a simple fix thank you,karon
Post by frane on May 6, 2011 7:18:04 GMT -5
I never knew that. Great tip! Fran
