Extreme Minerals
"Start using that rock equipment or else!"- Your Wife
Member since May 2011
Post by Extreme Minerals on May 13, 2011 14:37:30 GMT -5
Does anyone know where the best place or places are to buy grits and coolants in quantity is? I'm setting up a shop with about 10 saws and 14 tumblers and am looking for the best price possible. Thanks, Tim
Post by quartz on May 13, 2011 21:18:10 GMT -5
For silicon carbide, try Electro Abrasives, Buffalo, N.Y. 716-822-2500. We use hydraulic oil for saw coolant, many are getting tractor fluid from farm implement dealers.
charles kuchar
Member since November 2010
Post by charles kuchar on May 14, 2011 19:44:33 GMT -5
what about parafin oil? the folks i have met in my rock club say that parafin oil is the one i should use in my ten inch saw. i do have hydralic oil for my hydrostatic drive in my tractor. would that suffice? thanks. charlie
Post by johnjsgems on May 14, 2011 21:53:51 GMT -5
If you an oil distributor in your area look for "white mineral oil" or "tech grade mineral oil". Key things are low viscosity, high flash point, low odor. Avoid any vegetable based oil.
Post by stefan on May 17, 2011 8:46:49 GMT -5
Quartz- thanks for the tip- I'm about 30 to 40 minutes from those guys- gonna have to check them out!
Post by johnjsgems on May 17, 2011 20:07:38 GMT -5
Good luck if you are talking Electro Abrasives). That is the brand name from both Covington and Johnson Brothers. When I contacted them to buy in bulk direct I was told I had to buy from either of their SO CAL distributors, Covington or JB. Please let me know if you are successful buying from them direct,
Extreme Minerals
Post by Extreme Minerals on May 19, 2011 22:22:37 GMT -5
I too am having trouble with Electro. Contacted customer service twice with the promise of a quick email quote with no luck. Contacted them again today and talked with the Vice President of the company who apologized over and over and said he would personally send the quote today and when he asked me what kind of quantity we were talking and I said 100 pounds of 6 different grits his voice seemed to trail off. As for the quote, you guessed it, nowhere to be found! Guess you have to buy by the train load to get these guys to act!
Post by connrock on May 22, 2011 7:50:28 GMT -5
I've bought 50lb bulk grit from here and have had no problems,,,,, You can buy in larger quantities as well,,,,, www.milessupply.com/connrock
snuffy
Member since May 2009
Post by snuffy on May 22, 2011 20:14:59 GMT -5
Kingsley North still has free shipping on 60/90 grit.50 lbs
snuffy
