unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on May 25, 2011 8:05:02 GMT -5
HI All, It was recommended to me that I can use windshield washer fluid as a coolant with my 6" Rock Rascal model J trim saw. If I choose to use this instead of just water do I need to dilute the windshield washer fluid with water? Or do I just use it undiluted as is done with my car? I have the 1 gallon bottles of the blue stuff.
Thanks
Stu
Post by Toad on May 25, 2011 8:40:20 GMT -5
Isn't it mostly water with a bit of anti-freeze?
brent
Member since November 2008
Post by brent on May 25, 2011 9:21:09 GMT -5
Be careful. The "anti-freeze" in it could be methanol. Check on the ingredients or check the MSDS.
Post by stefan on May 25, 2011 9:29:12 GMT -5
Never heard that one before- must be the surfactant that aids in cooling? For a smaller saw like the 6" I would just go with water and maybe a little borax. Make sure to drain the water and wipe everything down after you finish cutting- else your gonna get Iron Oxide all over the blade and such (RUST). I also give my saw a quick spray of WD40 and a second wipedown.
brent
Post by brent on May 26, 2011 21:07:31 GMT -5
Methanot keeps the washer fluid from freezing. I buy it in bulk under the names, methanol, methyl hydrate, and widshield washer anti-freeze. The summer version would just have soap in it.
Post by Roller on May 26, 2011 21:33:39 GMT -5
slabs should be squeaky clean!
Post by Fossilman on May 26, 2011 22:00:13 GMT -5
Yuppers.I would watch out for gases,some mixtures can get you sick just from the smells.........
