lisatech
Member since May 2011
Post by lisatech on May 31, 2011 10:39:27 GMT -5
No matter what I seem to do with this cab, I can't seem to finish it. I am pretty confident that the scratches are still coming from the 14,000 belt as I have worked on one direction, see the scratches follow that direction and rotated to the next side and the scratches shift to that direction. I have tried the lightest touch to firm pressure and neither seem to make a difference..... Any hints??? Or is it just a process that I need to keep working the belt? I have a round cab that doesn't seem to be afflicted by these scratches... go figure... Attachments:![](//storage.proboards.com/1258779/thumbnailer/Ac9Ny7rTnLz1RqjE1Wg8.jpg)
Post by jakesrocks on May 31, 2011 11:21:49 GMT -5
Is there any chance that you've contaminated your belt with coarse grit form another belt ?
Post by johnjsgems on May 31, 2011 11:24:38 GMT -5
If it is a new belt it may need dressing. If you don't have a 220 dressing stick try holding a flat agate against the belt with plenty of water flow.
Post by Hard Rock Cafe on May 31, 2011 11:28:26 GMT -5
Hi Lisa,
I don't think you should see any scratches from a 14k belt. I hate to say it, but you may need to back up a belt or 2. At least that has worked for me when I've had similar problems.
mc2
Member since April 2009
Post by mc2 on May 31, 2011 11:31:11 GMT -5
I have had a lot of problems similar to that with my 8000 grit belts. Thanks to John of jsgems' help, I think I have finally got past that. Due to my lack of experience, I was not getting the belt 'dressed' out properly, and, as I would continue to try to figure out what was wrong, I believe I would also damage the belt by pressing a stone into it too hard, maybe. At any rate. John's suggestion certainly helped me out. Hope it helps you also, it can be frustrating!
Mike
Post by mohs on May 31, 2011 11:33:42 GMT -5
is that carnelian your working? it sure is a pretty piece hard material
I'm working the same problem with a piece of agate fine scratches I'm having some success with the 8000 grit wheel using lots of firm vigorous pressure, with a circular, let it slide motion
its bit of an obsession and I'm not sure who's going to win but were both hard headed
good luck! Ed
lisatech
Post by lisatech on May 31, 2011 15:38:36 GMT -5
Thank you to everyone for your comments!
Jakes - I don't think I've contaminated the belt as I have a gravity water feed and with only one drum, have to switch belts for the different grits. Stone is always rinsed and dried before the new grit.
Chuck - lol, gmta - I've been back and forth twice now... but hey, maybe third times a charm...
John & Mike - I have some scrap agate that I'll try to dress the wheel with and maybe it will take it down just that much.
Ed - you make me laugh - me, being as hardheaded as I am too! I don't know specifically if is Carnelian, just as it was an agate in my brother-in-laws box of goodies.
I am fortunate that my brother-in-law is busy with other things and his girlfriend wanted her laundry room back so his equipment is on semi-permanent loan with me - :-) Now I am just figuring out how to use it. The belts are mine and have been working through breaking them in - the rest are behaving themselves other than this 14000 one...
Onwards and downwards, well down to the basement anyways to take another stab at it...
peachfront
Member since August 2010
Post by peachfront on May 31, 2011 15:41:18 GMT -5
I'm not the most experienced person here, but in my personal experiences, I go with "what Chuck said." You say you don't have the problem with the round cab, and that's pretty much an "aha" for me. I don't have the same problem with domed tops as with those pesky flat tops, and it is not being caused by the 14K belt. It's being caused by I didn't really get the sanding perfect on the 600 belt. It wouldn't be unknown for me to have to back up to the 200 wheel. There is something about the way I work the stone that makes it much easier to grind/sand out scratches if there's a domed rather than flat top. I may also install a magnifying glass to give me a better shot of seeing those scratches before I take it all the way to the polish. By the time I'm wearing reading glasses with shop safety glasses on top, and I'm working a wet stone, some scratches are getting past me on the flat tops until I polish them up and out they "pop."
A technique I may try, for future triangles etc. is to polish the slabette first in the tumbler to get a nicely polished flat top and THEN cab the stone.
Post by mohs on May 31, 2011 15:59:47 GMT -5
O.K. I just stopped on my lunch break and got on this stone. After this morning of really smoothing the stone t out on the 8000 grit I mean... I really had a high polish with scratches all over it My theory was get the stone as micro-smooth as possible then go back to re-sanding I just re-worked the stone on 600 grit. Nova and started seeing vast improvement! Ha HA! I mean I really worked that stone. Good pressure and do the curve round-over thing under the periphery of the wheel Good light --good concentration. Part of the process is mind control. ![:P](//storage.proboards.com/forum/images/smiley/tongue.png) Something I don’t have a whole lot of. But I try. ! Anyway work that stone smooth, fast, slide, curve, dome. You’re the boss!! Continue on to finer grades. You will succeed!! But take time to eat. Cause I got roll right now. Go thru a drive later on Ed
