mikeinsjc
Member since June 2010
Post by mikeinsjc on Jun 4, 2011 13:53:47 GMT -5
I am looking for the smallest saw I can find that still has an auto-feed. Any recommendations?
I am not opposed to trying to improvise the auto feed. If any of you have had sucess doing so, I'd appreciate your advice.
Post by Rockoonz on Jun 4, 2011 14:47:37 GMT -5
If you want a fully enclosed saw Lortone used to make a 10 inch saw, maybe they still do. In trim/slab saws there may be an 8 incher out there but mostly 10 inch. I have an old Raytech 6 inch trimmer with a vice and auto feed but it's missing the arbor and sump. I'm planning to try to make the top fit a HP sump and arbor, but that might be awhile.
Lee
Post by Sabre52 on Jun 4, 2011 16:50:17 GMT -5
I'm not sure why you would want to go smaller than a ten inch. You can always cut smaller rocks with the ten inch saws, blades are not that pricey, and often you want to use the whole vice size for a larger specimen. Why limit yourself to tiny rough by getting a tiny rig?. Besides with tiny saws, it's actually faster and easier to push the vice by hand. I started lapidary at age 10 or 11 with an old sears six inch saw that had a vice that you just fed into the blade by hand. Worked swell and was easy to use....Mel
Post by johnjsgems on Jun 9, 2011 12:08:45 GMT -5
I agree with Mel. Covington and Lortone both make 8" power feed saws but 10" would be not much more. Any 6" saw will cut pretty short rocks (usually 1 1/4"-1 1/2"). Can't see where a power feed would be useful for anything that small. Any lapidary saw with a vise and good blade would slab tiny rocks hand feed with no problem.
Post by Rockoonz on Jun 9, 2011 21:28:12 GMT -5
John, you're right about the usefulness of a 6 inch saw with a power feed, the only reason I could think of would be cutting smaller pieces of really high end stuff where you want to keep blade kerf loss to a minimum. The problem with that is that there is no way to align the vice travel with the blade like a regular slab saw so most trim/slab saws make lots of blade marks on the cut surface that require time to remove, and pretty much negate any material savings.
Lee
Post by johnjsgems on Jun 9, 2011 21:59:38 GMT -5
I wouldn't recommend thin blades on 8" or 10" saws with power feed either. Deflection would wipe out blades quickly. Running a thick blade on a 6" saw would negate any kerf loss advantage over 8"-10" saws.
