ahmed
Member since August 2011
Post by ahmed on Aug 6, 2011 16:43:38 GMT -5
We want the type of epoxy resin for the following uses Process stability and turquoise stone hardener Cretaceous This type of epoxy resin will seep into the stone and the stability of the stone and stone hardener Can you help get this resin Thank you for your cooperation good Ahmed
skystone
Member since April 2011
Post by skystone on Aug 7, 2011 10:51:12 GMT -5
Stabelizing Turquoise is usually done under pressure. The liquid plastic or polimer is water thin. Turquoise is porrus but not that porrus. You probably wouldn't get very much penatration. Mike
