creekscavenger
Member since September 2011
Post by creekscavenger on Sept 8, 2011 5:56:59 GMT -5
Hello, I'm new at this and I was wondering what size wire is needed and what tools are needed to get started learning to wrap stone jewelry? I know that it is going to take a long time to get a technique down, but I need to know where I should start. Thanks....Jay
unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on Sept 8, 2011 6:05:48 GMT -5
creekscavenger
Post by creekscavenger on Sept 8, 2011 6:41:33 GMT -5
Thank you so much!!
Post by drocknut on Sept 8, 2011 23:05:33 GMT -5
Welcome to the forum and I agree with Stu, Randy's tutorial answers a lot of questions and gives good advice. Also check out the tutorial on the wire wrapping section about swirls don't by Marie (Superioragates). I use 22 gauge dead soft square wire and 21 gauge dead soft 1/2 round wire for my wraps. A lot of it is personal preference. As far as tools, the middle of the line jewelry pliers are good because they aren't as expensive but also aren't so cheaply made they break too easily. I generally use chain nose, round nose, wire cutters, and flat nosed pliers for wrapping. There are lots of other pliers some specialized but I started with the basics and still use them today. Don't like to pay lots of money for special pliers I'd only use once in a while. Hope that helps.
Post by Bikerrandy on Sept 10, 2011 21:22:01 GMT -5
Diane- not sure if I mentioned before, but I used to do my bindings with dead soft half-round, but later found that (after advise from Jeremy) the half hard half-round does cleaner bindings. It worked for me anyhow but you're right, it's personal preference.
Post by drocknut on Sept 10, 2011 21:45:40 GMT -5
Thanks Randy, I might have to try the half hard half round to see if it works like that for me, but will have to wait until I can afford some more wire. Thanks for mentioning it.
