Post by texaswoodie on Sept 9, 2011 18:31:59 GMT -5
I need to replace the boards on my vise but am having a heck of a time finding 1/2 inch oak. Any suggestions?
Curt
Post by johnjsgems on Sept 9, 2011 18:44:00 GMT -5
Curt, if you have any cabinet shops in your area see if they will sell you some scraps. Any hardwood would work. A lot of people use plywood. It grabs rocks better but has to be replaced more frequently. I generally use pine or doug fir scraps between my hardwood jaws and the rock to get a better bite on irregular rocks.
Post by jakesrocks on Sept 9, 2011 19:08:42 GMT -5
What size boards do you need ? I have some scrap oak, and a surfacer to shave them to 1/2". Also have some rock hard maple. Don
Post by texaswoodie on Sept 10, 2011 15:53:23 GMT -5
Thanks John!
Don, we have a cabinet shop not too far away. Let me see if I can get some scrap and save you some trouble. Thanks!
Curt
blessed
Member since January 2010
Post by blessed on Sept 10, 2011 21:57:03 GMT -5
Lowes has 1/2 oak. 2, 4, & 6 inck wide & 2, 3, & 4 ft long. They also have popular and select pine, same size. Cabinet shop should have scraps for free. James
Post by Roller on Sept 10, 2011 22:18:44 GMT -5
i just busted a corner as well ! great post ! ... i was also thinking johns idea ... hard wood in and soft out for grabbing ! ... wish someone mass produced something like that !!!!
Post by Rockoonz on Sept 10, 2011 23:22:54 GMT -5
I have been using pallet oak from equipment pallets, it's a lower grade oak and it holds up pretty well, but tends to be just soft enough to allow the rock to compress it a little bit to get a better grip.
Lee
Post by jakesrocks on Sept 11, 2011 11:43:39 GMT -5
If you have a tractor supply dealer or a Macs Tools, they have very hard rubber belting in various thicknesses that would give a firm grip on odd shaped rocks. I've made them for my 10" covington, and they seem to work fine.
Steve
Member since June 2005
Post by Steve on Sept 11, 2011 18:53:00 GMT -5
Wish this had been posted a week ago. I just replaced plywood with plywood on 2 saws.
Post by jakesrocks on Sept 11, 2011 21:54:04 GMT -5
Nothing wrong with plywood, if you used marine ply. Regular plywood will soak up cutting oil and quickly start to de-laminate.
On my big saw I use oak faced jaws and softwood shims. Those shims that home builders use to square up windows and doors work good. And a bundle isn't all that expensive.
Steve
Post by Steve on Sept 11, 2011 22:49:09 GMT -5
Sigh, live and learn. Guess I'll be replacing again soon. Thanks Jake (making a guess at a name)
Post by jakesrocks on Sept 12, 2011 14:27:43 GMT -5
Actually Steve, it's Don. Jake is my dog and best rockin buddy.
If you used regular plywood, you should be able to get about a year out of them. When I make new jaws for my saws, I make several pairs at the same time. That way I always have a spare set if I need them. Don
Steve
Post by Steve on Sept 12, 2011 19:30:22 GMT -5
Thanks Don. Give a treat to Jake for me.
jspencer
Member since March 2011
Post by jspencer on Sept 14, 2011 0:34:15 GMT -5
Curt I have some good old red oak here I use for my vises. I can send soem your way if you can`t locate any near you. Let me know what dimensions you are looking for and I can precut it here for you.
