Post by morerockspleaz on Nov 21, 2011 20:47:38 GMT -5
I see that a lot of people myself included are cleaning up old and used equipment. One of the best products I have found for removing rock sediment and rust is a product made by Zep called Calcium, Lime and Rust remover. It comes in a gallon jug. I bought it at home depot cost about 10.00. I used it full strength. IT WILL REMOVE PAINT AT FULL STRENGTH. Or at least it did for me. It will burn your hands if you do not use gloves. I wanted to pull my equipment down to bare metal for repainting and was surprised when it did. I have used a brass brush and some sand paper in a few places. Before After I had already cleaned by hand the left hand side and it has taken me hours, I wish I had found the product earlier. I wrapped an old clean sock around it a poured it on and left it alone for about 20-30 min and sprayed it with clean water. You may find a little residual rock dust after it dries, but it comes of with a simple pass of a brass brush. Hope this will help someone with their cleaning process. I have no ties to the Zep Corp. but sure do like their product. BeLinda
Post by quartz on Nov 21, 2011 21:40:10 GMT -5
Looks like you pulled a genie out of a bottle to clean your genie. Thanks for the tip, I'll be trying it.
Post by frane on Nov 28, 2011 21:21:31 GMT -5
Sure made quite a difference on that one! I may have to try that stuff! Fran
Post by rocklicker on Dec 1, 2011 21:30:53 GMT -5
Wow that sure cleaned up nice. Do you think it would leave the paint on if it was diluted? I got some pretty gunky equipment myself. Steve
WarrenA
Member since November 2003
Post by WarrenA on Dec 27, 2011 0:16:50 GMT -5
I have a saw that had some oil in it long enough to turn it into an extremely stick varnish that is almost impossible to remove, I finially gave up and just left it.
Post by Rockoonz on Dec 27, 2011 23:26:58 GMT -5
Warren, penetrating oils like WD40 do wonders as a solvent to remove petrified rock snot.
Lee
Post by jakesrocks on Dec 27, 2011 23:46:20 GMT -5
I had the same type of buildup on my Genie motor. I sprayed it with that orange cleaner and let it sit for a while. It removed all of the buildup, without removing the paint.
Don
