shermlock
Member since August 2011
Post by shermlock on Dec 27, 2011 14:22:37 GMT -5
What do you folks use as spray guard material on Nova wheels? My machine has pvc guards but they don't distribute the water much. I'm thinking a softer material but I don't want to wear down the nova wheels either. Thanks, Scott
Post by jakesrocks on Dec 27, 2011 15:03:38 GMT -5
Scott, if you have a Tractor Supply near you, Buy some rubber belting. They have it in several widths and thicknesses, and sell it by the foot. Another thing you could try is a plain old kitchen sponge. Don
shermlock
Post by shermlock on Dec 27, 2011 15:06:56 GMT -5
Don, I actually have some of that rubber belt material...that won't heat up the novi wheel too much? Thanks, Scott
Post by jakesrocks on Dec 27, 2011 16:00:14 GMT -5
Not as long as you're using plenty of water. Years ago we used pieces of inner tubes. Don
Roger
Post by Roger on Dec 27, 2011 16:34:16 GMT -5
I use a piece of old car floor mats either rubber or cloth.
Roger
shermlock
Post by shermlock on Dec 27, 2011 17:06:06 GMT -5
I use plenty of water so that shouldn't be a problem! Thanks for the quick replies guys! Scott
spicer m
Member since October 2008
Post by spicer m on Dec 27, 2011 20:47:35 GMT -5
Post by Rockoonz on Dec 27, 2011 23:22:45 GMT -5
I use the generic green scotch brite-like pads cut to shape. they do a real good job of spreading the water across the wheels and keep the spray down nicely.
Lee
Post by chad on Jan 3, 2012 17:12:46 GMT -5
I go to the carpet store and get the 50 cent remnants... shaggiest stuff I can find. It saturates and spreads the water over the wheel, and stays really wet itself against the wheel.
zarguy
Member since December 2005
Post by zarguy on Jan 5, 2012 0:11:11 GMT -5
I use cotton Karate belts I find at the thrift store. $2 gets me a yard or so. I cut them into pieces just the right length & glue under the lip of my hood. Not only does it keep down the spray, but it spreads the water over the entire width of the wheel. The belt on the left keeps water from splashing out of the hood. Lynn
docharber
Post by docharber on Jan 22, 2012 20:04:18 GMT -5
NOte in Lynn's pics the belting on the right has the corners notched inward to the edge of the wheel. With rubber material, the water will be guided inward tyo the wheel and more water delivered. I did this to my cabber and the water flow onto the wheel increased a good deal.
Mark H.
