Post by Rockoonz on Dec 30, 2011 16:59:34 GMT -5
It's normal, happens while the expando is expanding. As long as it's not vibrating excessively and wanting to dance around the table once it's up to speed you're fine.
Lee
Post by tntmom on Dec 30, 2011 18:14:20 GMT -5
Well, it certainly doesn't dance around the table but I do feel a vibration when holding a cab up to it. I don't feel that on my Ameritool. I wonder if I messed it up.... Are there other things I should check on this machine that could affect vibration besides the bushing?
Post by Rockoonz on Dec 30, 2011 19:18:22 GMT -5
The vibration you feel is probably the splice in the belt. is it severe enough to make it hard to hold the cab?
Lee
Post by tntmom on Dec 30, 2011 19:28:43 GMT -5
Well, I have been using a piece of porcelain jasper to play around with. Not too hard to hold, I'm using my fingers only, no dop. It hasn't flown out of my hands but there is definitely a big difference in the smoothness versus my lap.
Post by mohs on Dec 30, 2011 22:41:34 GMT -5
If you think the expando is running out of round there a few things to check
the first is to check the shaft/spindle/arbor (for now on called arbor) to see if that is running smoothly
remove the expando drum, turn on the machine, and with your thumb feel if the spinning arbor is running smooth
if it has (run out) or a wobbly feel to it that's a source problem that needs correction
it doesn't sound like you have that problem tho your bushing went on centered and straight so all should be a go
The other tricks is to turn the drum after its mounted on the arbor O... about 1/4 turn and re-tighten sometimes that re-centers the wheel
I feel a wobble on my drum on just 1 side it irritates me -then it goes away
have fun mostly
Post by Rockoonz on Dec 31, 2011 12:23:38 GMT -5
It is not safe to run expando wheels w/o a belt on them. There is a chance that they may come unglued from the hub. The warning is probably printed on the drum.
Lee
Post by jakesrocks on Dec 31, 2011 12:46:13 GMT -5
Agreed Lee. Never run an expando without a belt. You may get away with it a few times, but eventually it's going to bite you.
Don
Post by tntmom on Dec 31, 2011 13:46:54 GMT -5
Thanks for the tips! Yes it states not to run without a belt but I'm glad you explained the reason why.
Lee, I think you are right. I believe I am feeling the splice. Later when I get more belts I will compare.
Woody said to use these dry and spritz with silicon spray. What's the best brand to buy?
Post by jakesrocks on Dec 31, 2011 13:51:52 GMT -5
Krystee, the splice will probably start to smooth out after a few cabs.
Any brand of silicon spray should work. Just something from the local auto parts or hardware store.
herchenx
Member since January 2012
Post by herchenx on Mar 7, 2012 11:09:50 GMT -5
Krystee, is this belt the one you use to shine your OB?
Post by tntmom on Mar 7, 2012 12:12:52 GMT -5
Lol John... yes, you discovered my secret weapon I've polished ob with felt too but this belt does a much faster and better job!
Post by johnjsgems on Mar 7, 2012 12:50:09 GMT -5
It is my understanding the vibration was caused by a cracked drum bushing (cracked while installing). I've sent replacement bushings and all is well now I believe. And yes, it is very common to see a wobble as the drum starts to turn or slows to a start. It is a lot of bulk to spin but should smooth out at speed.
Post by tntmom on Mar 7, 2012 13:14:14 GMT -5
Yes, John is right. I cracked one of the bushings using too much force getting it onto the shaft. The replacement John sent me worked perfectly. He also explained to me that expandos need to run at a higher speed to expand correctly. That was my other problem. It is all working perfectly now though. Thank you John, you're awesome!!!
StoneCrazy
Stone Crazy
Member since July 2011
Post by StoneCrazy on Mar 7, 2012 14:17:40 GMT -5
It looks like a 8 to 10 oz top grain hide. The smooth side is out? In my leather work I use the ruff side out with some jewelers rough to sharpen cutting blades.
Liz
Post by johnjsgems on Mar 7, 2012 15:18:03 GMT -5
Most people are using them with diamond compound so prefer smooth side out. For polish compounds rough out would probably be better. I have him make a few rough side out belts each order.
Post by jakesrocks on Mar 7, 2012 15:36:58 GMT -5
Hey John, how much are you getting for those belts in 6" X 2-1/2" ? I might be interested in one of each.
Post by johnjsgems on Mar 7, 2012 19:09:27 GMT -5
Prices:
6" X 1.5" $34.95 6" X 2.5" $44.95 8" X 3" $49.95
Prices may rise slightly in not too distant future. After Woody got the belts developed my cheap source for resin belt backings dropped them. Lowest priced resin belts I can find are a couple of dollars more each belt. I'll probably hold these prices for RTH members as long as I can. All prices are plus shipping but USPS is pretty low priced on something this light.
