Post by tandl on Feb 17, 2012 10:39:09 GMT -5
Post by Drummond Island Rocks on Feb 17, 2012 10:59:48 GMT -5
I have heard some horror stories of tumbling the petosky stones and having them crumble up becuase they are so soft. Yours look good. Did those go through 60/90 with those other rocks and fossils? I have not seen too many posts of tumbled fossils so I look forward to following the posts on this batch. Chuck
Post by tandl on Feb 17, 2012 11:12:58 GMT -5
Yes, 60/90 . as you can see the paint rock came out great . it is softer than the petoskeys . there were several other petoskeys in this batch . they came out good too. Some of the other fossils, with more quartz need more time . i tried to match the hardness on these, but the variance is like a solid line . As far as petoskeys , i did not put in some that i have , that are chalcedony and quartz replaced .
Post by FrogAndBearCreations on Feb 17, 2012 11:23:46 GMT -5
Cool batch!
Post by Toad on Feb 17, 2012 11:30:44 GMT -5
Doing a great job with more difficult material. Looking good.
Post by Jugglerguy on Feb 17, 2012 18:22:56 GMT -5
I've read that Petoskeys can be roughed in 60/90 but have more problems in later stages. Are you planning to try finer grit on them?
Post by helens on Feb 17, 2012 19:29:00 GMT -5
What is the hardness of that batch? I guess those fossils are all agatized? A lot of what we find here in florida are limestone fossils. They're like chalk, you can break em up with your fingers if not careful. I don't think I can tumble them at all. Those came out beautiful!
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Feb 18, 2012 0:32:00 GMT -5
That is one of the best mix of patterns and colors I've seen in a batch of tumbled rock. What in the heck is that cream and brown and green stripped rock?
Post by tandl on Feb 18, 2012 10:19:25 GMT -5
Im thinking the finer grit will not affect them badly, and will need plenty of pellets to cushion them . Daniel - I dont know . it is a strange one, guess it is a metamorphosed sediment.
Post by talkingstones on Feb 23, 2012 20:44:11 GMT -5
YOU MICHIGANDER!!!! YOU TUMBLED TOSKIES?!?!?!?!? Can you really do that? Details Please!!!!!!!!!!
Post by tandl on Feb 23, 2012 21:29:46 GMT -5
Well, theses are not done, but i did some many years ago, and went by the book of one of those toy tumblers. i dont think it is that hard, knock on wood. there is quite a variance in petoskey in hardness and texture, as with the other fossils . the very soft ones seem to be more pitted too . These are Illinois finds . these are softer than some i have that have quartz replacement.
snuffy
Member since May 2009
Post by snuffy on Feb 23, 2012 21:33:07 GMT -5
Me likey those!Nice unusual batch.
snuffy
Post by talkingstones on Feb 23, 2012 21:38:57 GMT -5
6lb, I'm thinking this is rotary? How many days?
Post by tandl on Feb 23, 2012 21:42:25 GMT -5
Thanks ,Snuff! Quite a compliment-coming from you ! i hope my luck continues. i sure could use more tumblers and money for grit. kinda expensive for my budget
Post by tandl on Feb 23, 2012 23:10:14 GMT -5
6lb, I'm thinking this is rotary? How many days? Yes, rotary-6lb . i wrote it down , have to add it up. i was shutting it off at night, and back on as i went out to the shed, i probably forgot the write the time , some days. Looks like about ten days,but...
colliel82
Member since November 2007
Post by colliel82 on Feb 24, 2012 12:40:46 GMT -5
Great looking batch. I would have thought you might end up with a barrel of sand with those.
Post by frane on Feb 25, 2012 20:21:56 GMT -5
Wow! You sure have some amazing items in that batch! Fran
Post by krazydiamond on Feb 25, 2012 20:48:22 GMT -5
i'm so impressed! those look great!!!! need to know your secrets!!!!!!!!!!
KD
NDK
Post by NDK on Feb 25, 2012 23:32:14 GMT -5
Awesome batch so far Ted!
Nate
Post by tntmom on Feb 26, 2012 0:09:47 GMT -5
SAWEEEET Ted!!! I am bookmarking this, don't want to miss the progress! WTG!!!!!
