darstcreek77
Member since April 2011
Post by darstcreek77 on Feb 19, 2012 16:59:13 GMT -5
Here is my project It isnt rusted just dirty he must of really liked red rock ! Both motors runs great , vice works great bearing are nice and tight the blade has 80 or more per cent of its cutting edge left its a MK its a power feed (works ) I am going to rewire the complete saw light , motors ,cut off switch , the light cover is a mason jar , well Its a now till summer project , oh I have to install a pump for the oil . Attachments:
darstcreek77
Post by darstcreek77 on Feb 19, 2012 17:07:01 GMT -5
! more shot Attachments:
jason12x12
Member since October 2011
Post by jason12x12 on Feb 19, 2012 18:03:24 GMT -5
excellent piece of equipment
shermlock
Member since August 2011
Post by shermlock on Feb 19, 2012 18:35:56 GMT -5
That is exactly the type of project I am looking for! Nice score. Scott
Post by Rockoonz on Feb 20, 2012 1:38:40 GMT -5
A "Magnum Hydro", the 24" at the local rock club shop is the same manufacturer. It has a screw feed and a air cylinder. The lever sticking out the side has a clamp on the inside to hold a piece of grindstone so you can sharpen the blade while making a cut. The threaded holes on the edge of the vice are there are there for tapered head screws so you can use it as a slab grabber to get the last slab off an end cut. After you clean out the threads put in some set screws to keep the rock snot out of the threads when you're clamping rocks in the vice. A pretty impressive design
Lee
Post by Woodyrock on Feb 20, 2012 2:50:36 GMT -5
With the dried rock snot this one has, I would take it outside, turn it on it's side, and put the pressure washer to it. Then get it dry as fast as possible. This is a very good starting point for a very good saw.
I am sure you will have a few cooking hot days coming up soon, and one of those would be a good time to do the power clean.
Woody
NDK
Post by NDK on Feb 20, 2012 19:40:49 GMT -5
Cool saw! I like the idea of threaded holes in the end of the vise, I may have to add that to my vise when I resume my build.
Nate
