Post by FrogAndBearCreations on Feb 29, 2012 16:52:47 GMT -5
Too cool!
unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on Feb 29, 2012 19:25:05 GMT -5
Hi Jim Thanks for the science lesson on the super not so secret any more process of ring making. They look really great. Now for some suggestions. With your great talent in carving, why not do some scrimshaw work around the rings. You can do different themes to focus on different markets. You can also mount small stones around the ring to give them some sparkle. Then we come to the idea of some enamel work or inlay work. What about cutting out small shapes through the ring like cresent moon, stars, clover, spade and so on.
I wonder how pet wood would hold up as a ring Stu
Post by Deleted on Feb 29, 2012 19:55:54 GMT -5
Post by helens on Mar 1, 2012 4:44:57 GMT -5
That's so interesting! Thank you for posting all the pix of the process and generously sharing. Those pictures are fantastic, and your descriptions are great! I'm not going to try making rings like that, but I love learning about how it can be done. You definitely write better than you read! j/k. Is it only jade that's strong enough to withstand making rings? Agate is too brittle, what about jasper? Or are all the quartz-based stones no good? Have you tried Chalcedony? I saw the most incredible looking rings in Chalcedony... it's a small step to go from what you are making to making these: jewelhistory.com/2008/06/13/is-mineralogy-jewelry/There's another designer that does them also in Chalcedony, and I can't remember her name now... I'll post a link if I think of it.
adrian65
Member since February 2007
Post by adrian65 on Mar 1, 2012 5:49:52 GMT -5
Great looking rings. Interesting process, also.
Related to your explanations, I wander what "caca" means to you, 'cause in my language it means literlally "poop" or "crap" ;D
Adrian
unclestu
Post by unclestu on Mar 1, 2012 9:11:30 GMT -5
Great looking rings. Interesting process, also. Related to your explanations, I wander what "caca" means to you, 'cause in my language it means literlally "poop" or "crap" ;D Adrian Adrian in English the word caca also is boop but is usually said with reference to baby poop. It is a sanitized word for sh*t Stu
Post by Deleted on Mar 1, 2012 10:38:54 GMT -5
Adrian - Our slang is almost impossible for people outside the US to pick up unless you live here for a long time. When I was in China I had to be very careful about what words I used because the people there would have no idea what I was talking about. Most English speaking people do not have a clue how difficult the language is. I used slang in the first sentence (pick up) that would confuse most foreigners but we think nothing of it. Helen - hahaha Sometimes I do not write so good also. I re read very carefully before posting. Thank you for the heads up on the rings. They are beautiful. A Duchess probably does not go rollerblading or slam her hand on the bar at a new years party though. lol That ring probably had to be made entirely with a rotary tool because it would be difficult to drill that shape. I guess that it could be drilled then the part under the finger carved away to make it smaller. I have no way of differentiating between chalcedony and agate and think they are pretty much the same thing? ?? I look at jasper pretty much the same way and had the same results with it as I did with the others. A couple of things that I learned was that a ring too thick is painful to the fingers next to it so adding strength that way is not a good option. A longer ring such as the agate ring on the post you pointed out adds strength but drilling a piece of agate that thick would take hours unless I bought special equipment to force water inside the hole saw. There is probably a reason that person only made three. The center could be removed with a rotary tool, which he probably did but that would also take an enormous amount to time. An established artist could get away with that because they can charge an arm and a leg for the ring. I am of the American fast and furious set who just wants to make a buck instead of art. (not all of the time though) I did have some luck with quartz not shattering as bad as agate but I am not a big fan of quartz because I have not had real good luck with polishing it especially in the tumbler. Even though the hardness is the same as agate, quartz is easier to work with as far as drilling and cutting because it's structure is not as tight. I have taken nephrite and jade rings, put them on the center of my little finger and whacked them on a hard wood table until my finger was bruised and the rings did not break. One whack with an agate or similar material and it would be broken. The jade is some super tough stone yet so much easier to work with it is hard to believe. I can drill five or more jade rings in the time it takes me to drill one agate ring. The only draw back is that they are pretty much all the same unless a person could find white or black jade. The agate rings are very colorful and second to none in the beauty department so that is a bit of a let down. I have tried to think of ways to line the agate rings with silver but then I would have to get into another form of art and the sizing would be a problem. I have given it a lot of thought and like the "water flows down hill" the nephrite and jade are the way to go. I may try Stu's suggestion and fiddle with carving but I do not see any great things coming of it. Jim
peachfront
Member since August 2010
Post by peachfront on Mar 1, 2012 11:15:15 GMT -5
Jim, I have a block of material that someone told me was Pink Jade. Is this a nervy question, or is it possible that I could send you the stone, and if you can work it, send me back one ring and you are welcome to keep the rest? You have a U.S. shipping address, right? I'll take a photo in a little while if you have any interest. My Agate ring is long gone, as you say, it broke! This pink material is not Agate but as I'm not familiar with Pink Jade, I guess my only real worry is that it is not Jade either. It is not a dyed stone like the Pink Jade I just googled. I got it from an estate in I think 1992. Let me know if you'd even be interested in looking at it, and I'll snap a photograph I can post. To make one ring, it looks like it would be quite an effort...although I certainly appreciate your detailed posting.
Post by Sabre52 on Mar 2, 2012 9:56:07 GMT -5
Peach: Pink jade is usually thulite which is a massive pink form of zoisite. Some is pink and green where the green is probably nephrite jade or a relative like tremolite. The pink areas are softer than jade and if mixed with the green, tend to undercut. The pink is composed of interwoven crystals though so might hold together in a ring but would probably be less durable and more prone to scratching than solid jade.....Mel
peachfront
Post by peachfront on Mar 2, 2012 13:49:38 GMT -5
Oh gosh, I'll be disappointed if it's Thulite but nothing would surprise me!
peachfront
Post by peachfront on Mar 18, 2012 17:56:20 GMT -5
Update: These rings are even more impressive in person!!! Wow. Thanks, Jim!!!
Post by Deleted on Mar 18, 2012 23:24:02 GMT -5
You are very welcome. And thanks for the trade. Everyone loves that stone. If the shine gets a little dull just rub them with 3000 sandpaper and they should shine right up. Jim
Post by Pat on Jul 12, 2012 21:48:49 GMT -5
Jim, you are going to have all the RTH people happily wearing rings!
Post by Deleted on Jul 12, 2012 22:17:25 GMT -5
That would be cool. Starting a trend like Madonna. Will that make me famous or does that work the other way around. LMAO Jim
Tom
Post by Tom on Mar 5, 2013 23:24:13 GMT -5
Thanks for the tutorial, I am going to have to try this out
Post by Pat on Mar 5, 2013 23:49:12 GMT -5
Using Jim's method and his help, I've made rings of Wyoming jade, Blue G Lawsonite and blue lace agate. Haven't chipped any of them and I wear them frequently.
Post by Deleted on Mar 6, 2013 14:38:14 GMT -5
Ok, Which one of you stole the photos? lol Not sure what happened but I will try to figure out which photos and put them up again. Sorry Jim
hubrocks
Post by hubrocks on Mar 8, 2013 1:56:48 GMT -5
Those are some great looking rings!!
Post by jamesp on Mar 8, 2013 9:23:34 GMT -5
It is not how much materials you have-it is what you do with it that counts.A little bit sure went a long way Jim.You have patience of Job.And do not worry,you have a ways to go before you catch up w/Madonna,sorry a loooong way:>
danb
Member since March 2011
Post by danb on Mar 24, 2013 22:20:06 GMT -5
Very cool! How fast do you run the drill press when you are cutting the slabs? How long does it take you do do a cut? Thanks for sharing your process!
