Post by Deleted on Aug 13, 2013 10:46:30 GMT -5
I missed the last post Dan, sorry. With smaller hole saws (up to 1/2 or 5/8) I run the drill press at max, 3000. With the larger hole saws I slow it down to the slowest setting which is 560. I run the up and down method of drilling just like if I am drilling small holes in agate. Jim
Post by jamesp on Aug 14, 2013 8:59:55 GMT -5
I am equally impressed with your tooling. The vise looks like it has been around since medieval times and the government test fired a few a-bombs clamped in it. I got 2 old drill press clamps like that. Could you imagine staring up at twist drills coming at you all your life. I like your customized processes very much. That's what makes new and unusual. You are my hero Jim.
plumberinaz
Member since June 2013
Post by plumberinaz on Aug 14, 2013 17:15:50 GMT -5
Great Job!
Post by Deleted on Aug 15, 2013 2:42:16 GMT -5
I am equally impressed with your tooling. The vise looks like it has been around since medieval times and the government test fired a few a-bombs clamped in it. I got 2 old drill press clamps like that. Could you imagine staring up at twist drills coming at you all your life. I like your customized processes very much. That's what makes new and unusual. You are my hero Jim. Well, take a close look at what it says on these clamps. Absolutely the best tooling around because I never would have figured that out. Jim
Post by rockpickerforever on Aug 15, 2013 9:09:50 GMT -5
Wow, talk about stating the obvious, LOL! If a person is not smart enough to figure that one out, they have no business using the tool!! Quick, get out of the shop, before you hurt yourself!! Don't touch anything!
Please note, I am NOT referring to you, Jim. Looks like you know how to use tools.
Speaking of, how's your project truck coming along?
Post by Deleted on Aug 15, 2013 11:58:40 GMT -5
Jim, I am just wondering why you don't use smaller sanding drums to finish the inside of the ring? Is the ring better that way? Just curious.
Post by Deleted on Aug 15, 2013 13:21:49 GMT -5
Wow, talk about stating the obvious, LOL! If a person is not smart enough to figure that one out, they have no business using the tool!! Quick, get out of the shop, before you hurt yourself!! Don't touch anything! Please note, I am NOT referring to you, Jim. Looks like you know how to use tools. I grew up on a farm and have had tools in my hands since before I can remember. Speaking of, how's your project truck coming along? I had a duh period with the pickup. It was running rough so I bought plugs and wires to see if that would help. I lifted the hood, looked at the distributor and figured out that the engine would run better if all eight wires were attached to the distributor. lol Connecting that eighth wire made a huge difference.
The only other improvement that I have made is new door pulls/arm rests. The part that you grab to close the door is local cedar and I put the same foam pad on the arm rest that is on the floor. Everyone that sees them goes "wow" so I guess I made a good choice. Thank you for asking. I am surprised that you remembered.Jim
Post by Deleted on Aug 15, 2013 13:29:22 GMT -5
Jim, I am just wondering why you don't use smaller sanding drums to finish the inside of the ring? Is the ring better that way? Just curious. Back then my rotary tool was down so I did not have much choice. I guess that I could have chucked a drum sander in the drill press and worked the ring on it but I did not think of that until I read your post. lol The only thing that I do on the inside is take the sharp corners off. My rotary is up and running now so I will use your suggestion. Jim
Post by rockpickerforever on Aug 15, 2013 13:38:26 GMT -5
Jim, you're welcome. It's a beautiful project, and I wondered how you were doing on it.
Post by Deleted on Aug 15, 2013 13:38:38 GMT -5
Definitely not a suggestion. Just a curiosity. I have no clue what makes a nice ring.
Post by Deleted on Aug 15, 2013 14:25:26 GMT -5
Definitely not a suggestion. Just a curiosity. I have no clue what makes a nice ring. I think it is a great suggestion and now that my rotary is going again I will give it a try. I have a lot of the little drum sanders. Jim
Post by jamesp on Aug 15, 2013 16:23:36 GMT -5
Yea how/where is that smoking truck?
What is adjustable on a clamp? just kidding
Post by Deleted on Aug 17, 2013 7:41:56 GMT -5
Yea how/where is that smoking truck? What is adjustable on a clamp? just kidding I think they must be talking about the rod going through the shaft. It is adjustable from one side to the other. Jim
Post by jamesp on Aug 17, 2013 8:48:32 GMT -5
Can you clamp metric sized pieces? I have metric and American adjustable wrenches.
Post by Deleted on Aug 17, 2013 9:08:07 GMT -5
Can you clamp metric sized pieces? I have metric and American adjustable wrenches. HAHAHAHAHAHAHAHA
