keystonecops
Member since October 2010
Post by keystonecops on Mar 10, 2012 22:49:26 GMT -5
Guy I bought the 20 from just threw this in. Had a guy at work had a egg he wanted cut. This thing works slick Later Clyde
herchenx
Member since January 2012
Post by herchenx on Mar 11, 2012 0:18:36 GMT -5
Cool!
jason12x12
Member since October 2011
Post by jason12x12 on Mar 11, 2012 3:08:16 GMT -5
how big is that egg . i need to make something similar for my little ten inch saw
keystonecops
Post by keystonecops on Mar 11, 2012 9:35:01 GMT -5
Jason, It fit in the palm of my hand. Cause of the nobbys onit it clamped good. If it didnt I woulda had to grind a groove aound the end. Later Clyde
Post by Sabre52 on Mar 11, 2012 13:40:14 GMT -5
Whew, never seen a slab grabber used that way. I always use mine for heels or nodule pieces that are already cut and have a flat side I put against the grabber. That looks like a blade breaking situation to me but if it works and you're willing to risk it what the heck.....Mel
Post by catmandewe on Mar 11, 2012 22:20:24 GMT -5
I have several of those slab grabbers, they work better than any other one I have ever used.
Tony
Post by Donnie's Rocky Treasures on Mar 12, 2012 7:49:14 GMT -5
How does it work? What is the trick to it?
Post by catmandewe on Mar 13, 2012 23:59:06 GMT -5
How does it work? What is the trick to it? The screw heads act as grippers, you can thread the screws in or out to get the desired depth, then you tighten up the closest nut till the grippers are good and tight, then you tighten up the back threaded rod in the opposite direction or outwards and it creates a pinch effect which in turn makes the grippers dig in a little more. One of the double sets is stationary, the other double sets rotates so you can virtually grip almost any shape. Then you grab the rock and try to shake the grabber loose, if it won't come off you can proceed to cutting, if it comes off you start over. Tony
herchenx
Post by herchenx on Mar 14, 2012 13:57:43 GMT -5
This thing looks great. I've only cut like 5 slabs this morning and already wish I had one!
Post by Hard Rock Cafe on Mar 14, 2012 14:56:26 GMT -5
