Post by mohs on Mar 31, 2012 18:51:44 GMT -5
Hello Everyone !! I’m pretty stoke about my first groove and wrap !! Long ways to go to grooviness but I accomplished some good things in between Like got my grinding bits off the Gryphon without a seize problem whhhooo hhoooo and attached a grooving disc! It works really great and will be new style of zipping the grooves for the pre-drilled holes on the hearts! Have lots to learn. How to create a bale, depth of cut, wire types & especially precision grinding an oval its lopsided--- like me mostly I can always take it a part & finesse grind Hope you think its pretty groovy thanks for looking GrooveE
Post by Pat on Mar 31, 2012 18:57:01 GMT -5
;D ;D ;D Definitely groovy! I intend to get groovy myself.
Post by Bikerrandy on Mar 31, 2012 19:00:54 GMT -5
Looks great!!
Post by talkingstones on Mar 31, 2012 19:14:45 GMT -5
Very groovy, Ed! Exceptionally so! Once you've gotten fully into the groove, maybe you can help me groove too! LOL! Enjoy and it looks great!
Cathy
Post by tntmom on Mar 31, 2012 19:17:49 GMT -5
Ed ;D ;D ;D, LOVE IT!!!!!!!!!
rockingthenorth
Member since January 2012
Post by rockingthenorth on Mar 31, 2012 20:06:52 GMT -5
great job
LarryS
SoCal desert rats
Member since August 2010
Post by LarryS on Mar 31, 2012 20:19:36 GMT -5
Ed,
Nice stone & wrap. I'm still waiting for my Parawire order so I can perfect my technique, which needs a lot of work.
Post by FrogAndBearCreations on Mar 31, 2012 20:32:33 GMT -5
Pretty cool groove!
Post by gr on Mar 31, 2012 23:24:59 GMT -5
Ed, nice!! check yer PM's
adrian65
Member since February 2007
Post by adrian65 on Mar 31, 2012 23:40:28 GMT -5
Looking good, Ed! Wire is going smoothly all around the cab, being hidden just enough to look good. Couldn't figure out how could you not use a coil wire at the bail and where are the ends of the wire, but then I figured out: the wires end at the top of the bail, which you twisted and then you masked with that jump ring or whatever it's called. Right? Adrian
Post by mohs on Apr 1, 2012 0:20:23 GMT -5
Hey Adrian yep twisted as you say then used a round piece of metal as a mandrel to make the loop then twist and cut-off
Then I used a-- what's called a lobster claw bale --- it basically pinches on lots of beaders use them pinch them into holes
anyway I use a bale to get the right orientation for hanging
Post by mohs on Apr 1, 2012 0:21:51 GMT -5
Thanks everyone ! I sure did enjoy finagling with it and look forward to crafting more Ed
Post by helens on Apr 2, 2012 6:05:42 GMT -5
That turned out wonderful Ed!!
