riverrock
Member since April 2010
Post by riverrock on Apr 1, 2012 10:08:18 GMT -5
now i have read more stories on line about this unit. power and shocks issuses should i just bite the bullet and get a genie? i realy liked the easy use of the flat top.
Post by jakesrocks on Apr 1, 2012 10:13:08 GMT -5
Yes, if you can afford one. I have both machines. The inland is OK for doing flat backs and specimens, but once you try the Genie, you'll never go back to cabbing on a lap. Your Inland laps and backing plates will fit the left end of a Genie, and you can get spin on discs for the right end.
Post by jakesrocks on Apr 1, 2012 11:21:45 GMT -5
Ooops ! My bad. I should have said that the 6" Inland laps and backers will fit the Genie. The 8" laps will fit the Titan.
Post by FrogAndBearCreations on Apr 1, 2012 11:53:56 GMT -5
new motors are under 100 bucks!
Post by johnjsgems on Apr 1, 2012 15:03:12 GMT -5
Ameritool or High Tech Diamond flat laps are about 12 times better than Inland as far as durability and quality. Motor price is generally not an issue as they are made to be used. They do cost more but about 1/3 as much as a Genie. If you want to do cabs you would love the 6 wheel convenience of the Genie.
riverrock
Post by riverrock on Apr 1, 2012 16:22:12 GMT -5
thanks i will look into both flat tops .
Post by Rockoonz on Apr 1, 2012 22:24:51 GMT -5
You can check craigslist and ebay as well, older belt drive flat laps and slant cabbers are preferrable to the ac/dc units in plastic cases, but the variable speed does have it's plusses. Our old Covington gets much use and it will never die.
Lee
