Post by Toad on Apr 19, 2012 21:19:34 GMT -5
Anyone ever tumble schorl? Any tips?
Thanks
Todd
Post by johnjsgems on Apr 20, 2012 13:06:49 GMT -5
The schorl in my area was not gemmy enough to do anything with other than specimens. If you can grind a piece you should get a pretty good idea if it will polish and hold together. If it will tumble it would be pretty nice.
Post by Toad on Apr 20, 2012 14:07:22 GMT -5
I think it is a pretty hard material, but maybe prone to fracture - so maybe treated like obsidian??
thomtap
Member since December 2007
Post by thomtap on Apr 20, 2012 14:17:46 GMT -5
I tried some once, and it took a beautiful polish, but I couldn't get the pits and valleys out of the stone. Where it was smooth, it was great, but the deeper I ground, the more pits were revealed. Maybe a better quality would have worked great...
sweatpea
Member since October 2022
Post by sweatpea on Oct 27, 2022 10:50:56 GMT -5
I just tumbled a chunk of black tourmaline i found by the road. I have a habbit of stopping when conditions look right for a crystal release. There were several chunks that ran from crumbling to solid. As expected the crumbling ones did not survive but the solid one got a nice pearly almost velvet luster below the surface. This is my 1st run through the stages of tumbling and i know my impatience and inexperienced ignorance caused the crystal to be dull yet i can still see the luster inside. Now that i have read a little i will run it through pre polish and polish with like rocks. Basically i did a mix of rocks and ran them for a couple days at each stage. Without proper cleaning between stages. So lots of room for improvement but still it turned out well.
quartzilla
Member since April 2020
Post by quartzilla on Oct 27, 2022 16:47:32 GMT -5
I suspect only crystals from a pocket would tumble without pits or fractures. Most black tourmaline found is of the “frozen” variety where it eroded out after being entirely encased in quartz of feldspar.
