Mark K
Member since April 2012
Post by Mark K on Apr 28, 2012 16:40:13 GMT -5
Does anyone have a photo of this unit. The site has a drawing and it is worthless.
I aqm trying to see if it is a preform maker or something else. I want to get a preform maker, but can't seem to find one.
Post by jakesrocks on Apr 28, 2012 17:01:24 GMT -5
These Covington pieces clamp into a slab saw, and help to make the cuts for a sphere preform. You will still have to grind the sharp points and edges off before putting the preform in your sphere machine. There is a company that makes a better pre former. I'll see if I can find a link to it. Don
juzwuz
Member since April 2010
Post by juzwuz on Apr 28, 2012 18:28:40 GMT -5
Post by jakesrocks on Apr 28, 2012 19:25:24 GMT -5
That's the site I was looking for. I bought my cup adapters from this guy. A little search of his site will turn up a short video of the sphere indexer in use.
Post by jakesrocks on Apr 30, 2012 22:19:39 GMT -5
Mark K
Post by Mark K on May 1, 2012 21:47:48 GMT -5
Yes. this is what I was looking for.
Thanks all.
hh5
Member since January 2012
Post by hh5 on May 4, 2012 23:20:58 GMT -5
Thanks for the links, Some good videos on using the preform tool.
Harold
Mark K
Post by Mark K on Jan 8, 2014 19:17:27 GMT -5
I just went to order one but the shipping was asinine. I have found that people who charge ridiculous shipping charges are usually the first one to screw you.
Guess I am not going to order one after all.
Post by Deleted on Jan 8, 2014 20:48:21 GMT -5
Just make your own or look for a simpler jig then that one. Here is mine, works great. Tim
Mark K
Post by Mark K on Jan 8, 2014 22:21:17 GMT -5
Well, that thing looks like a true work of art.
I have no idea how you would use it.
Post by DirtCleaner on Jan 8, 2014 23:36:49 GMT -5
Well, that thing looks like a true work of art. I have no idea how you would use it. I would think that the cube would have to be larger than the "wing" that points to the left in the photo. And a bit longer than the length of the jig. I've been building one in my mind for the last few weeks and then this pic shows up.
Post by Rockoonz on Jan 9, 2014 0:24:15 GMT -5
I just went to order one but the shipping was asinine. I have found that people who charge ridiculous shipping charges are usually the first one to screw you. Guess I am not going to order one after all. Rod is as trustworthy as the day is long. I see him at shows all the time and have purchased many of his gadgets. I just went through his site to the calculate shipping part, not unreasonable at all. I am sure he ships by UPS and puts money and effort into safely packing it, and $22.50 is too much?!?
Mark K
Post by Mark K on Jan 9, 2014 3:45:02 GMT -5
I do. I find that to be quite excessive. I talked to him and he says that paypal made it that way. I am naturally suspicious of people I have no experience with. I guess it comes with the job I do.
juzwuz
Post by juzwuz on Jan 9, 2014 15:06:14 GMT -5
Just make your own or look for a simpler jig then that one. Here is mine, works great. Tim Tim, Would you mind showing how you use that jig? I'm still looking at various ways to make a sphere preform. Justin
Post by Deleted on Jan 9, 2014 15:46:29 GMT -5
Justin, visualize clamping that jig onto a tile saw table. It's positioned so the cuts are made in the correct place. Soon, you will understand where that is.
Now put the cube - corner down - into the angle. Now the cube is sitting at a 45 degree angle like a diamond. Flat face of the cube is facing the blade and the back of the saw table. Hold cube in place by hand and feed across the saw blade. Carefully trim, rotate 90 degrees, trim again, keep rotating and cutting until all the corners are clipped into a preform.
In tha case of Tim's image the point of view is from near where the saw blade would be. Saw blade would be slightly right of the camera in this image.
I have seen the same from two pieces of angle iron welded in a sort of 96 position so when placed on the table the same orientation is achieved.
Post by Deleted on Jan 9, 2014 15:50:42 GMT -5
I just went to order one but the shipping was asinine. I have found that people who charge ridiculous shipping charges are usually the first one to screw you. Guess I am not going to order one after all. Rod is as trustworthy as the day is long. I see him at shows all the time and have purchased many of his gadgets. I just went through his site to the calculate shipping part, not unreasonable at all. I am sure he ships by UPS and puts money and effort into safely packing it, and $22.50 is too much?!? Rod is cool. No doubt. But $22.50 for small parts is silly. I have a 36# hunk of railroad track/anvil that will ship for $16. I don't know the size of the part in question, but if it fits in a MFRB then the price is almost double what it should be. UPS is overpriced so they can pay their overpaid union staff.
Post by Deleted on Jan 9, 2014 15:57:42 GMT -5
I watched the videos. I like how the sphere indexer does not require starting from a cube. Instead it starts from to parallel faces. The finished preforms are very uniform, this makes for faster hand grinds.
Post by Deleted on Jan 9, 2014 19:21:44 GMT -5
Post by DirtCleaner on Jan 9, 2014 19:27:04 GMT -5
Now to figure out how to clamp it on a vertical vice.
juzwuz
Post by juzwuz on Jan 10, 2014 19:56:17 GMT -5
Thanks Scott and Tim! Clears things up for me. I do have a vertical vise so might have to modify things a bit. I was still toying around with the idea of making a simpler sphere index jig but haven't worked on it very much.
