LarryS
SoCal desert rats
Member since August 2010
Post by LarryS on May 4, 2012 16:33:15 GMT -5
Bought a gallon of Gem Lube from Kingsley North to give it a try. It's a water soluble coolant similar to Lube Cool. Gem Lube is fantastic! Doesn't foam like Lube Cool and time will tell to see how the blade holds up. My blade didn't need sharpening as much. So far so good.
Post by Pat on May 4, 2012 16:38:01 GMT -5
Larry, would that be necessary on any size saw? I'm getting a 10" soon. Thanks.
LarryS
SoCal desert rats
Post by LarryS on May 4, 2012 16:45:44 GMT -5
I've been using Lube Cool for over a year in my 10" Covington. Was experiencing all kinds of problems. It foams like crazy and had some premature blade wear, mainly with the last batch I bought. Gem Lube is mixed the same, 10/1 with water and you can tell the ingredients are totally different. Smells different too.
