Mazanec
Member since March 2004
Post by Mazanec on Mar 31, 2004 11:55:52 GMT -5
I see some tumblers have 2 or more barrels. Would this be good for maybe doing grit in one and polish in another? I read you can reuse polish, so I thought this might be a good idea...wouldn't get grit in polish. Or am I missing something?
James
Member since October 2003
Post by James on Mar 31, 2004 12:32:17 GMT -5
You would most likely have to buy extra barrels. For instance. The two barrel that come with the tumbler would be for 60/90 grit and 120/220. Then buy two extra barrels, one for pre-polish and one for ploish ONLY. That is at a minimum. I actually have eight barrels total for my T2 tumbler. I use the different grit barrels depending on the circumstances.
llanago
Member since January 2004
Post by llanago on Mar 31, 2004 14:12:09 GMT -5
Tom, if you have/or buy a Lortone QT66, I have an extra barrel I'll sell you for $25.00 plus postage. It's never been used. I got two extra barrels from a guy on ebay and thought I would need them, but have since bought two more tumblers that I use just for pre-polish and polish.
I just use the QT for coarse grit and can only tumble two at a time. I will still have an extra barrel, so I can part with one of the two extras I bought
If Tom doesn't want this barrel and someone else does, let me know.
Post by sandsman1 on Mar 31, 2004 22:09:44 GMT -5
i do llana if tom dosent
Post by docone31 on Mar 31, 2004 22:40:16 GMT -5
I have ended up with three bbls for my 2bbl tumbler. I exclusively use one for polish, and the other two I use for all grits. I have found, even starting with coarse, running full cycle tends to even the grits to match the cycles. I do, also wash both the stones and bbls between each cycle. The polish bbl I never use grits and run a dunnage load between different polish runs, full seven days.
WarrenA
Member since November 2003
Post by WarrenA on Mar 31, 2004 22:42:55 GMT -5
llana, if the sandsman doesn't take the barrel give me a email and I will take it off your hands. I to cannot believe what some people are paying for used stuff on ebay. Warren
Mazanec
Post by Mazanec on Apr 1, 2004 9:45:05 GMT -5
I am just looking into getting started, so I haven't decided what (if anything) to get. If anyone else wants the extra barrels, they are yours.
Post by creativeminded on Apr 1, 2004 15:44:02 GMT -5
When I got my new Lortone tumbler I just went ahead and bought three extra barrels to complete a full set-up for all four stages.
Tami
