Post by rockjunquie on Jun 17, 2012 12:37:58 GMT -5
Don't know where I should put this, but it's about cutting rocks-- just little round holes. I was wondering can someone direct me to information about how to drill holes in cabs? I tried searching here and couldn't find anything. I need to know the kind of drill I need and the bits. We have a drill press, but I'm assuming I can't use it with water. Thank you
Post by Bikerrandy on Jun 17, 2012 14:42:47 GMT -5
Forgot to mention, you'll need diamond bits. I think I may have some, not sure how good they are for lapidary but if I find them I'll let you know.
Thunder69
Thunder 2000-2015
Post by Thunder69 on Jun 17, 2012 20:37:44 GMT -5
Post by deb193redux on Jun 17, 2012 21:22:34 GMT -5
you can use you drill press with a pan of water. I would recommend the smallest core bot rather than a solid wire bot. the solid bits break easy and wear out quick
Post by rockjunquie on Jun 19, 2012 16:16:23 GMT -5
Thanks- y'all are great!
Post by Hard Rock Cafe on Jun 19, 2012 16:54:05 GMT -5
You'll also want to use a low drill speed to extend the life of your bits.
Post by Rockoonz on Jun 20, 2012 0:00:05 GMT -5
Chuck, we set the drill press to the highest feed then drill a little at a time by "pecking" at it.
Lee
