Post by kk on Jun 19, 2012 2:47:25 GMT -5
Have not had a lot of luck with the weather. It's been raining every day for the past 3 weeks. That is a pain in the rear as I have to cut outdoors. So a solution was to go back to my first love, Fire Agate. The first one is covered to the excess of 70% of color, but I tried too hard and cut through several attractive colors. Luckily it seems that thing has endless layers of colors. Not bad at a seize of 4 cm length and colors back and front No picture of the back yet as I'm still condsidering on carving something out of the back. The second was easy go as I just had to sleize off the top. Preform Some of the bubbles And then I saw two areas that need reworking So that still needs to be done until the weather clears up. And then finally on to the next project Day 1 Thanks for looking, have a great and productive week, Kurt
pporky
Member since May 2007
Post by pporky on Jun 19, 2012 4:32:15 GMT -5
Wow thats some pretty fine workmanship I like the way you use the whole stone a true freeform.
Post by NatureNut on Jun 19, 2012 7:50:57 GMT -5
Oh wow, so beautiful Kurt. Jo
Post by Deleted on Jun 19, 2012 8:34:46 GMT -5
Beautiful fire agate KK. Is that a gecko I see peeking it's head out of the black stone? Jim
Post by paulshiroma on Jun 19, 2012 8:34:55 GMT -5
Great looking piece, Kurt! Paul
Post by Pat on Jun 19, 2012 9:03:08 GMT -5
Lovely material and workmanship as usual! Looks like a gecko to me, too.
Post by kk on Jun 19, 2012 9:23:07 GMT -5
Thanks everyone, Beautiful fire agate KK. Is that a gecko I see peeking it's head out of the black stone? Jim Yep, will be a lizard of sorts, if things work out (is the soft nonmagnetic dark sample coming your way Jim). Its a bit on the large side, so placing the legs and having it fit on a chain will be a bit of a challenge. Never mind though, in the end, its a test-run for trying out the subject on some Indonesian Chrysolla after this one. The fire Agates are OK, but still made too many mistakes, cutting through some desirable colors only to find lesser colors underneath. As always, playing the colors, needs regular practice and that leads to intuition that can not be missing when working this material. PPorky: Since I started with FA, I always try to keep true to form. I have no idea as to how Christopher and others manage to get those perfect edges when shaping their cabs into regular shapes.
Post by roy on Jun 19, 2012 9:30:11 GMT -5
real nice work on the fire agates
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Jun 19, 2012 11:24:27 GMT -5
Nice work Kurt. I also prefer following the natural shape of the color layers. I find that you lose too much color with cabbing this material. This is the biggest problem I have with over-aggressive windowed rough as well...by the time the windower has stopped to look at the piece, he's already blown through several good layers of color and there's no longer a natural contour of complete layers to follow and carve out. All you can do at that point is cab it up and hope for the best.
Post by gingerkid on Jun 19, 2012 11:29:59 GMT -5
Love your fire agates, kk! You shouldn't down rate your work!! What material are you using to carve the lizard? Hematite?
deniseh
Member since June 2012
Post by deniseh on Jun 19, 2012 15:21:41 GMT -5
I like your workmanship Kurt. Beautiful design. I can see the colors and the bubbles inside.
Post by kk on Jun 19, 2012 16:41:14 GMT -5
Love your fire agates, kk! You shouldn't down rate your work!! What material are you using to carve the lizard? Hematite? I don't know what material it is. Its one of the things that I found last month. Very soft (for me), but does not crack or fracture easely. Possibly slate??? Welcome to the forum Denise. You will find lots of people here to talk. Show them your wonderful work.
Post by christopherl1234 on Jun 19, 2012 17:39:06 GMT -5
I love those Fire Agates Kurt. You are correct when you say that it takes practice and intuition when cutting this material. I am very impressed with your carving. I am awaiting the photos that follow on your progress on the reptile.
Post by Bikerrandy on Jun 19, 2012 20:10:33 GMT -5
Beautiful work!! I've never seen that much fire before, very cool!!
Post by krazydiamond on Jun 19, 2012 21:11:48 GMT -5
i have to agree with Randy, that is some of the best fire agate i've ever seen!
KD
Post by kk on Jun 20, 2012 17:00:36 GMT -5
Thank you! i have to agree with Randy, that is some of the best fire agate i've ever seen! KD That's hard to believe with all the material that is easily available back home. Best regards, Kurt
grayfingers
Member since November 2007
Post by grayfingers on Jun 20, 2012 17:32:48 GMT -5
I have only seen them in pictures, but that one has great fire! Love the shape as well. Bill
