itsandbits
Member since March 2012
Post by itsandbits on Jun 27, 2012 11:15:14 GMT -5
Hi I don't know if anyone else is doing it this way but I premake the border to the length needed to fit the stone and then thread the frame wire through and bend it around the stone making adjustments to the distance between the loops and the way the frame wire fits the stone so it looks even as I go along. I made the frame wire long enough so that I could use it for the bail and the other end to wrap the tucked bale wire to secure the top. please ignore the poor craftsmanship, colour and attempted embellishments as copper is all I have, only have uncoated needlenose, and I was trying something out with the curlycues. I have been working on and off for a while trying to come up with something to contribute and this is it; try it, you'll love it. Use contrasting frame or border wire as suits the stone you are doing. This is my fourth actually finished wrap. Attachments:![](//storage.proboards.com/1258779/thumbnailer/yRC5dg2c8RYbzD4r9fQJ.jpg)
itsandbits
Post by itsandbits on Jun 27, 2012 11:16:55 GMT -5
This is the back of the stone and shows how clean looking it can be without the embellishments, Thanks for looking Lloyd I should add that I cut my stones with a pretty fine edge because the stone I mostly work with is so tough but if you have a cab with too big of bevel you could cut it down or make the loops bigger and splayed outwards more and fold them slightly to fit the bigger bevel. Attachments:![](//storage.proboards.com/1258779/thumbnailer/H0cebPW9tJSpRJ7aMpU9.jpg)
Post by FrogAndBearCreations on Jun 27, 2012 11:50:06 GMT -5
Looks good!
hubrocks
Member since April 2011
Post by hubrocks on Jun 27, 2012 13:32:17 GMT -5
I like that lots, very clean very pretty!
Post by upsided0wnducks on Jun 27, 2012 14:12:57 GMT -5
I do like it, I wish I could see both front, back and a side view though, as it helps see exactly how you did things ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Krista
itsandbits
Post by itsandbits on Jun 27, 2012 15:16:46 GMT -5
Hi Krista, I prewrapped the border on a stiff pc of 14g and alternate the loops from one side to the other by doing 1 1/2 wraps around the 14g and then used a nutpick; about 3/16" diameter to form the loop over before going back down to the 14g and wrapping 1 1/2 and coming back up the other side to form another loop and keep going back and forth that way making loops on alternate sides of the 14g. Hope that helps, the pictures I have up are front and back. I will do a tut with pictures if anyone wants.
Post by susand24224 on Jun 28, 2012 1:05:04 GMT -5
I like it as well--looks very clean.
Post by Donnie's Rocky Treasures on Jun 28, 2012 8:31:44 GMT -5
I also like it & I think a tut would be great, please!
digital123
Member since July 2012
Post by digital123 on Jul 2, 2012 7:14:49 GMT -5
The Wire Wrap method is very clear Correct , THis looping Represent the Clearity your work.centerless grinding is the Wire that is very good for the wire related work , your Working is so good.
NDK
Post by NDK on Jul 2, 2012 19:58:44 GMT -5
That is a very cool way to wrap! Could be used for a man or woman's wrap too, depending on how you finish it off.
Nice work! Nate
