James
Member since October 2003
Post by James on Apr 3, 2004 2:40:18 GMT -5
I just found a really cool new type of tumbler. It's almost like a hybrid of a rotary tumbler and a vibratory tumbler. Covington Deluxe Tumbler Ideal for rock polishing, gold and silver castings - also has a time saver in cleaning, deburring and polishing small parts, jewelry casting ans shell casings. Has a 3-way tumbling action. First Action: The stones (or casings) tumble in the bottom corner of the barrel and criss-cross from side to side. In the Second Action, the hexagon barrel shape forces the stones to abrade and change position within the mass six times per revolution. In the Third Action, the slanted back of the barrel moves a portion of the stones gently up and down while rotating. This third action is a Covington exclusive. Measures 21" L x 9" W x 12" H. fan cooled. 1/18 HP 110 volt, 60 hz motor. Solid polyvinyl barrel. One gallon capacity, lifts from frame for easy cleaning and access, also designed with a self burping cap for the "no gas problem". has a cast aluminum chassis, Dupont nylon bearings, V-belt drive. Unit comes complete with belt guard, instructions, and guarantee. www.covington-engineering.com/deluxe_tumblers.htmNOW I NEED ONE!!! ;D
James
Post by James on Apr 3, 2004 2:42:22 GMT -5
The thing even has a "self burping cap." Lol...
tjmax
Member since March 2004
Post by tjmax on Apr 3, 2004 6:25:18 GMT -5
pricey sucker
SirRoxalot
Post by SirRoxalot on Apr 3, 2004 8:51:11 GMT -5
Pretty nice, but does it do windows?
Post by creativeminded on Apr 3, 2004 11:48:53 GMT -5
Somebody mentioned a cement truck for tumbling, and look what someone found a small cement barrel. LOL Tami
James
Post by James on Apr 3, 2004 14:33:57 GMT -5
It doesn't do windows but I'm sure it does rocks.
James
Post by James on Apr 3, 2004 14:42:02 GMT -5
tjmax
Post by tjmax on Apr 6, 2004 14:28:55 GMT -5
bschultz
Post by bschultz on Apr 6, 2004 17:15:57 GMT -5
TJ, are egchain? Did you win? If so , let us know how it works. That design does look interesting. Bob
tjmax
Post by tjmax on Apr 6, 2004 17:21:41 GMT -5
Yes i sure am and i will. ;D
