Mazanec
Member since March 2004
Glass
Apr 3, 2004 18:47:06 GMT -5
Post by Mazanec on Apr 3, 2004 18:47:06 GMT -5
When I went to bermuda as a child we collected bits of class that had been rounded by the waves and sand. Anyone try this in a tumbler? What do I have to do different, if anything?
Allagash
Glass
Apr 3, 2004 19:09:49 GMT -5
Post by Allagash on Apr 3, 2004 19:09:49 GMT -5
Great question. We have a jar full of glass that we've collected from the beaches in Maine, I never thought of trying to make some. Before I tie up a barrel I'd like to hear if anyone else has tried it.
Glass
Apr 3, 2004 20:02:51 GMT -5
Post by hermatite on Apr 3, 2004 20:02:51 GMT -5
I've made faux seaglass. I just busted up bunch of blue glass water bottles and dumped them in the tumbler in 220 grit for a week. Then, because it wasn't beat up enough to my liking (ie: still pretty clear with no frosting) I dumped them in 60 grit for another week and am happy with the results. I'd suggest if you're interested you might try the coarsest grit first, checking every couple of days until it gets to the point you like.
Glass
Apr 3, 2004 21:43:25 GMT -5
Post by docone31 on Apr 3, 2004 21:43:25 GMT -5
Glass can be tumbled and get excellent results. A good week with 60 grit will give seaglass, the full cycle with all grits and polish will give smooth lozenge type glass. Glass is primarily quartz and it behaves like it. You will find some glass that will not co-operate under any circumstances however. New beer bottle glass is an example. That needs to be heated first.
Mazanec
Glass
Apr 4, 2004 11:12:31 GMT -5
Post by Mazanec on Apr 4, 2004 11:12:31 GMT -5
"That needs to be heated first". 100 degrees Celcius? 200 degrees? 500? A thousand? For a minute, hour or day?
Glass
Apr 4, 2004 17:39:16 GMT -5
Post by docone31 on Apr 4, 2004 17:39:16 GMT -5
I would go about 1300 degrees f. Let the glass glow, and let it cool normally. Another cool trick is to take glass marbles, heat them, and throw them in ice water. makes interesting patterns inside the marble.
