cabjunky
Regency Rose Plume
Member since November 2008
Post by cabjunky on Aug 5, 2012 8:52:57 GMT -5
A used Highland Park M-3 14/16" table top saw that I picked up at a local yard sale. The person selling the saw had used it heavily for a while, and then just stopped using it. It had wiring issues on the on/off switch, and a broken spring on the feed dogs. New wiring, spring, belts, paint, and a router table, and it's ready to join the rest of the family of Higland Park saws (6", 10",14/16", AND 24"). Fresh from the yard sale A Few restored Pics Robert
robsrockshop
Member since August 2012
Post by robsrockshop on Aug 5, 2012 9:03:48 GMT -5
Sweet! Those are the best.
shermlock
Member since August 2011
Post by shermlock on Aug 5, 2012 9:04:49 GMT -5
Great job! Scott
unclem
Me
Post by unclem on Aug 5, 2012 16:29:32 GMT -5
I like what ya done there!! Good job!
Post by Rockoonz on Aug 5, 2012 23:14:19 GMT -5
Nice job of fixing up a nice saw. The later style saws that roll on square rails are the best.
Lee
robsrockshop
Post by robsrockshop on Aug 7, 2012 6:52:11 GMT -5
When you get time can you please let me know the flange size and the depth of cut if it had a 16" blade on it? Thanks! I am asking because I built a 16" swing arm saw and it's leaving some minor saw marks and I think part of the reason might be the small arbor flanges of the Covington AR14 arbor as this saw takes advantage of the whole blade and when you have smaller flanges I seem to have a little variance running level across the center of the blade. I don't plan on changing it, it works fine it's just something im curious about. Thanks.
Post by johnjsgems on Aug 7, 2012 9:30:31 GMT -5
1/6 the blade diameter is the recommendation from MK for flange washers.
borock
Member since April 2011
Post by borock on Aug 7, 2012 10:49:15 GMT -5
I wished we had yard sales like that in Ga.
robsrockshop
Post by robsrockshop on Aug 7, 2012 14:11:15 GMT -5
Yeah i've seen the 1/6 guidelines, which is bigger than what I have currently. When I build a larger saw ill be using the right size to avoid any of the problems, which btw I have the equipment to build that stuff, lathes, mills etc so we'll see what I can come up with.
riverbendlapidary
Member since September 2006
Post by riverbendlapidary on Aug 7, 2012 15:08:04 GMT -5
great saw, should last just about forever!
Post by rockpickerforever on Aug 7, 2012 15:31:33 GMT -5
You made that puppy look better than new! You did a great job with it, now go cut some rock and get it all dirty! Jean
cabjunky
Regency Rose Plume
Post by cabjunky on Aug 7, 2012 16:43:25 GMT -5
Jean, I ran some rough through it over the weekend, so it's not all clean anymore. It had petrified rock snot on everything, which took a power washer, and alot of elbow grease to get it clean enough to paint it. Almag gets pretty nasty after it sat in a saw for that long, but it never looses that awful smell!!! Robert
