unclem
Me
Member since August 2012
Post by unclem on Aug 8, 2012 13:41:27 GMT -5
I would like to rip this old wood. I really like the wavy grain of it. But it has issues. I dont think there is any way I can slab this and keep it together. when cutting a mess like this, does it come down to cut or not to cut? there does not seem to be any good axis I can get a hold of this old wood. I think I am gonna end up with a bucket of Tumblers. any advice would be appreciated. ;D
Post by deb193redux on Aug 8, 2012 15:39:25 GMT -5
You might try soaking for a few days in activated epoxy that has been diluted with acetone to keep it from setting. Just don't let the acetone evaporate and you should get good penetration.
Post by jakesrocks on Aug 8, 2012 16:06:09 GMT -5
Beside the epoxy soak, after the epoxy has had a couple days to cure, glue your pet wood to a block of wood. Clamp the wood in your saw vice and slab away.
Post by Sabre52 on Aug 8, 2012 18:16:53 GMT -5
You have to ask yourself if it's a good enough hunk to risk having to buy a new blade. Pet wood is a notorious blade breaker...Mel
Post by catmandewe on Aug 8, 2012 21:02:07 GMT -5
What Mel said. Everytime you cut something like that you are risking your blade. If it comes apart while you are cutting you will either be hammering your blade or buying a new one. Sometimes they hold together, but sometimes not.
With that said, looking at your pictures I think you can get 2 or 3 slabs off the top end (second picture) before it falls apart, I wouldn't cut past the first seam though and I would try to get as much rock inside the vise as possible. If you do try it I wish you luck!
Tony
unclem
Me
Post by unclem on Aug 14, 2012 20:48:48 GMT -5
jason12x12
Member since October 2011
Post by jason12x12 on Aug 14, 2012 23:46:52 GMT -5
cool! it worked.. great patterns in that stuff..couple pitts. no big deal
