Post by stardiamond on Aug 8, 2012 20:36:39 GMT -5
I got a one pound chunk of Morrisonite online.It wasn't faced and is irregularly shaped with very little matrix.
Is there a grain in Morrisonite or can it be cut in any direction? I was planning on cutting the matrix of on two sides and see what shows up. There are five faces. The most exposed face is irregular and I am reluctant to cut there because of wasting material.
Suggestions welcome.
Post by deb193redux on Aug 8, 2012 20:46:47 GMT -5
you could window it on a course wheel
Post by catmandewe on Aug 8, 2012 20:49:24 GMT -5
Study it for a bit, it will let you know how it wants to be cut.
Tony
Post by stoner on Aug 9, 2012 23:23:03 GMT -5
I usually try to see what side has the best pattern(wet), take a slice and with it faced, if I don't like the pattern, I turn it 90 degrees and try again. Good Morrisionite is hard to cut wrong, it's all good.
Dr DG
Gone Fishing
Member since April 2005
Post by Dr DG on Aug 10, 2012 20:25:58 GMT -5
I working with some now, its all good, but it will turn your water and hands BLACK
