Don B.
Member since August 2012
Post by Don B. on Aug 12, 2012 8:47:23 GMT -5
I am just getting into cutting up rocks and polishing them and such. I decided my first project should be relatively simple, and I just want to cut up some of the rocks I have been finding, and make some beads for my wife. Figure it should be simple enough, just cut into cubes, drill some holes, and run through the tumbler. What size should I make the cubes though? I was thinking 1/2" assuming I lose some size to tumbling. Also, what size hole do you generally put through something to put it on a necklace or bracelet? I assumed it was better to drill before tumbling, but is it?
Post by jakesrocks on Aug 12, 2012 9:12:32 GMT -5
The beads will be easier to hold for drilling while still rough, but remember that the holes will fill with grit while tumbling. You'll need to make the holes almost surgically clean between tumbling stages.
I'll let the pro beaders on here suggest hole size.
Covington makes a nice little bead vice to hold the beads while drilling.
Post by Deleted on Aug 13, 2012 7:26:27 GMT -5
I would drill first for two reasons. It is fairly certain that you will have some breakage when drilling so break it before you tumble so you do not waste the space and time on something then break it. When you drill there is also a good chance that there will be a little breakage when the drill exits the stone but the tumble should clean that up.
Drilling little pieces is a pain in the butt so what I would do is lay out a slab and drill all the holes before you cut the slab. Then you can make all your cuts and presto you have beads. Just lay it out so that the saw cut leaves the same material as the thickness of the slab if you want them square. If you want them odd sizes just drill a bunch of holes and cut somewhere between them. If you use a cap brick (the one that goes on top with no holes) it makes the drilling much easier. Put the brick in a tub, lay the slab on the brick then add water until it just covers the slab. Drill away. I have pics and a tut on here if you need a better idea than my explanation. I am not a beader so I do not know what is the best size holes. I drill big holes for making rings. Jim
Don B.
Post by Don B. on Aug 13, 2012 7:39:35 GMT -5
Could you point me to your tutorial?
Post by Deleted on Aug 13, 2012 8:37:45 GMT -5
I just took another look at the tut and it is a bit outdated. I just took a bunch of new pics for a friend but I have not resized and put them on here. Your email is hidden so I could not send the pics there. It is much easier by email so if you do not want your email known to all you can pm your email to me and I will send the series of pics. Here is the old set up that I do not use any more. I have found a much easier way with the brick. forum.rocktumblinghobby.com/index.cgi?a....ad=50851&page=1Jim
Post by Deleted on Aug 13, 2012 18:30:07 GMT -5
drill it rough - (easier to hold) fill the hole with paraffin wax grind and polish as normal when finished, put in boiling water paraffin will melt and float to surface of water
easy peasy clean stones with clean holes.
peachfront
Member since August 2010
Post by peachfront on Aug 13, 2012 19:46:02 GMT -5
I filled my drilled holes with hard soap in the last batch but I will use the wax method next time. For the most part, making "beads" is not going to be economic unless you start with very unusual or very expensive material because there is a glut of cheap strands of beads out there. Stop by Michaels and check the display so you don't waste your time putting hours of work into a material that others will think you bought for pennies a bead. I have not actually made what I consider "beads" at all, just pendants: Still learning myself so don't chuckle too hard at my efforts! At least no one will mistake them for mass production. :-)
Don B.
Post by Don B. on Aug 13, 2012 22:36:51 GMT -5
We are just making them out of rocks we are finding on our own. The sand pits around here seem to be a treasure trove so far. It's not about whether not it's economical, it's about taking rough rocks that we found, and turning it into something that my wife enjoys. She really won't care what other people think about it, and will enjoy it for the work we put into it
peachfront
Post by peachfront on Aug 14, 2012 8:41:05 GMT -5
Since you're looking local rock, it isn't a problem and it sounds like a great project. The main issue is the hardness of the local rock and the difficulty of getting a good polish on it. Hope you will post photos of the results. However, for the record, it does suck all the joy out of the work you put into something once someone asks you questions like, "Oh, did you get the beads at Michael's [or insert cheap Chinese junk seller of your choice]?" No woman wears jewelry because they don't care what other people think. Making beads and pendants is extremely time intensive so it's something to watch out for, so the time isn't lost because the person refuses to wear the project. We don't have to learn everything from our own hard experience if others will share the mistakes they made ahead of us. :-)
Post by Deleted on Aug 14, 2012 9:26:32 GMT -5
psyon - In some ways I agree with peach and some ways I do not. I know women that will wear something that their husband or children have made no matter how bad it looks. If people make a comment their reply is my husband, son, daughter made it for me. The people that made the comment will usually say "my husband has never made anything for me, how nice of him". Ugly in one persons eyes is a treasure in anothers. For drilling small stones that you are going to tumble see Don's post.
I hope the other photos I send will help. What ever you are drilling either do it just under the surface of the water or have a good flow from a hose running across the top of your stone.
peach - I really like the larger holes in your pendants and may have to be a copy cat. I find that the tiny drills only last for minutes no matter where I buy them so I bought some a little larger with a ball end on them. Much more successful with them. Jim
Don B.
Post by Don B. on Aug 14, 2012 12:07:32 GMT -5
peach, we are finding some nice rocks at the local sand pits. They have been deposited by river, so they can be from anywhere along the drainage system. I got my small tile saw in the mail today (I have a habit of dropping hobbies quickly, so I stay cheap to start and work up), and I can already tell some rock is much harder than others when cutting. We are finding a lot of variety of what I believe are jaspers, petrified wood, and agates. It's all various forms of chalcedony, and seems to polish up well so far.
My wife and her friend are really into "quirky jewelry". She loves stuff made out of wood. She was at an art festival two weeks ago, and told me she saw some stuff made from rocks, and asked if we could make things like it, so I figured we could try.
Don B.
Post by Don B. on Aug 14, 2012 12:08:40 GMT -5
Post by Rockoonz on Aug 17, 2012 18:18:42 GMT -5
Here's an excellent place for bead making tools. Well, all kinds of tools for that matter. sphereproducts.com/beadmaking-diamonddrills.htm Scroll down. They do a lot of the west coast shows so we shop with them regularly. We have both bead vices and the 10mm bead adaptor. with the bead adaptor you can use a core drill to make a bead, place it in the adaptor and drill it perfectly centered. that way you drill halfway through from both sides, so no "blow out" from the drill exiting. Lee
dahjoat
Member since July 2012
Post by dahjoat on Aug 20, 2012 4:01:47 GMT -5
Hi Here is quick link for yah There are beads and there are Beads... THE BEAD MAKING TECHNIQUES OF DANIEL LOPACKI www.lopacki.com/howto/Cheers
