Post by Donnie's Rocky Treasures on Aug 19, 2012 8:57:58 GMT -5
I am having trouble cutting the Fordite! I don't want to use my 10" saw because it has oil in it. The tile saw I use with water. My tile saw blades are too thick so I would rather not use them so I tried a thinner blade with a crimped edge & it did not like the paint so would not cut it. What would be the best blade to use? I finally did try a 8" blade & I have room to spare, however it sure does cut fast so I got an 8" crimped blade from Lopaki, wasn't going to spend too much money on a blade until I knew whether or not I could make it work in the 7" tile saw. It works great! I just have to be very careful because that bugger sure does move fast! Definitely no room for mistakes with a thinner blade!!!!!!!! So the next step is what the heck am I going to use to cut the Fordite? ??
Post by Bikerrandy on Aug 19, 2012 9:21:22 GMT -5
I used a .012 blade with water (tile saw) to cut Victoria stone, I'd do Fordite the same.
Post by Donnie's Rocky Treasures on Aug 19, 2012 14:21:37 GMT -5
Randy, what size is your tile saw? I can't imagine using an 8" blade that thin going that fast on my tile saw. Plus I have a problem with the metal (I guess it's metal) dipping right in the center either side of the blade. (I wore it out!!!!!) Hard to keep anything even & straight!
Post by Bikerrandy on Aug 22, 2012 14:47:46 GMT -5
Hmmm, my blade doesn't dip in (I'm using a Workforce saw, an older one). I'm not afraid to spin any blades fast, just go slow with the cutting and you'll be ok. (sorry it took so long to reply, I forgot about this thread)
Post by Donnie's Rocky Treasures on Aug 23, 2012 15:51:47 GMT -5
Thanks Randy! It's not the blade, it's the aluminum top of the saw, either side of where the blade sticks out. I wore a dip in the aluminum on both sides so it's not level anymore!
Post by rockmanken on Aug 23, 2012 18:05:09 GMT -5
I use a 10" trim saw with water to cut my fordite. Has a .25 blade on it. I use a scrap piece of rock slab and just barely touch the inner metal part of the blade to keep it from wobbling while I cut with the other hand. Ken
Post by stoner on Aug 23, 2012 22:12:49 GMT -5
You can always use a coping saw(a woodworking saw), it cuts through the paint and you don't have to use any water with it! I've cut slabs with one and it worked fine.
hope
Post by hope on Aug 24, 2012 21:51:37 GMT -5
I am with Stoner on this one. Since Fordite is not really rock, coping saw, or a Sears scroll saw, small band saw or the like would do an excellent job on Fordite without the water or oil problem.
Hope
